Engine G2 banks
Page 1 of 1 [4 Posts]
atlb
PostPosted: Thu Jan 11, 2007 1:30 am    Post subject:  Engine G2 banks
Subject description: bank selection
I am using STEIM's junXion program to send MIDI messages to the Engine G2 (www.steim.org). Program change, continuous controllers etc messages work fine but I'm not having any success choosing banks. The manual does not go into this issue at length. Would someone please give me a blow by blow account of what the Engine expects to receive in order to change banks? cc32 + data message doesn't seem to work.
Thanks.
sheridan
Audio files: 27
PostPosted: Thu Jan 11, 2007 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Banks are typically selected using two controllers, controller 0 (Most Significant Byte) and controller 32 (Least Significant Byte). This allows for thousands of banks although usually manufacturers don't offer more than 128.
Using less than 128 banks allows banks to be changed using just one controller instead of two. Some manufacturers will use 0 (MSB), while others use 32 (LSB). To be honest, I don't know which the G2 uses.
Remember, if you want bank 3 for instance, you need to use a value of 2 as MIDI messages start at 0.
Also, make sure you have Program Change set to Receive and Send in the Synth Settings.
Hope that helps. Very Happy
transformer Sheridan
atlb
PostPosted: Thu Jan 11, 2007 2:04 pm    Post subject: bank selection
Subject description: engine g2 bank selection
Sheridan,
That helps. Thanks for the info. I got it.
alb
exeterdown
PostPosted: Thu Jun 18, 2015 3:57 am    Post subject:
Subject description: CC32 Blockout
I've been trying to use CC32 to do general MIDI controller tasks like change filter cutoff but the G2 doesn't seem to recognise it. It's also not in the list of assignable CCs.
I have a MIDI controller with a lot of knobs and it would be nice to keep them sequential, but with 32 missing it throws my whole set out.
