Nord lead NL1 arpeggiator hold
Page 1 of 1 [3 Posts]
Heathfinnie
PostPosted: Fri Jul 10, 2015 6:42 pm    Post subject: Nord lead NL1 arpeggiator hold Reply with quote  Mark this post and the followings unread
Is there really no easy way to latch the arpeggiator on the original NL1?
Audio files: 407
PostPosted: Sat Jul 11, 2015 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
You could get a sustain pedal. Get one with a polarity switch, so that when you press it, you release the held notes, instead of the normal operation, which is to hold notes when pressed down. Perhaps you can even set the polarity in the nord special settings as well, I can't remember now.
Muied Lumens Base Star
Heathfinnie
PostPosted: Sun Jul 12, 2015 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Robsol. I might end up having to do that. I was hoping for a "shift" + combination...
