El Capitan OSX Is it OK for G2 ?
Page 1 of 1 [18 Posts]
zenke
PostPosted: Sun Aug 14, 2016 5:05 am    Post subject: El Capitan OSX Is it OK for G2 ? Reply with quote  Mark this post and the followings unread
Hi
I have had a look around this list but I dont see any discussion regarding the use of G2 on the newest OSX, El Capitan.
Are people using this and manageing to still run the 1.62 G2 editor. I would be very interested to know.
Thanks
jamie
tomhall
PostPosted: Mon Aug 15, 2016 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
runs perfectly fine
zenke
PostPosted: Tue Aug 16, 2016 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much. Good to hear
rick
PostPosted: Sun Oct 16, 2016 3:58 pm    Post subject: Re: El Capitan OSX Is it OK for G2 ? Reply with quote  Mark this post and the followings unread
zenke wrote:
Hi
Yes, runs fine still on 10.11.6. I even tried the beta of Sierra, and the editor still runs on that too.
On OS X 10 the open dialog, to load patches, still works okay, but not as refined as with newer OS X applications for some reason. E.g. the directory last used is not remembered. (Just add a shortcut in the Finder windows left column.)
rick jansen
PS: hi all, it's been a LOOONG time. I see I last visited here in January 2005..
Audio files: 278
PostPosted: Sun Oct 16, 2016 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rick, thanks for the report :-)
zenke
PostPosted: Sat Oct 22, 2016 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all
I am having problems with using the G2 editor on el capitain. I can see that others are OK with it. I can open the editor but i get a ' major error' message and it will not conect to the aynth.
Do you have any suggestions?
rick
PostPosted: Sun Oct 23, 2016 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
zenke wrote:
Hi all
I get that message when the editor loses the USB connection, like when unplugging the USB cable. Is your USB connection ok?
rick
zenke
PostPosted: Sun Oct 23, 2016 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I tested my USB connection. Thanks for thta suggestions Rick.
However i have discovered that it is to do with 'allow apps downloaded from ..' which is in preferences, security and privacy.
If set to anywhere all is fine. Great!
Thanks jamie
zenke
PostPosted: Sun Oct 23, 2016 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, i spoke to soon. I can get it to connect, but it frequently disconnectes and requires reopening and reconnecting of usb.
rick
PostPosted: Sun Oct 23, 2016 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
See if there is anything in the console log?
Is the NM plugged directly into your mac''s usb, or through a hub or so?
Try another usb cable too.
rick
zenke
PostPosted: Mon Oct 24, 2016 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Yes I have it plugged directly into computer.
I dont really know how to use Console. I looked at it but I donet see anything which seems related to the Nord software.
ny idea what I am ;looking for ?
jamie
zenke
PostPosted: Mon Oct 24, 2016 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Any ideas what this means ?? this what i found in console after opening G2 editor.
24/10/2016 16:37:36.000 kernel[0]: 006356.151223 Nord Modular G2@1a150000: AppleUSBDevice::ResetDevice: <software>
24/10/2016 16:37:41.567 Nord Modular G2 Editor[658]: ATS: Invalid FontObjectID (3) - only low 16 bits are being passed in.
jamie
rick
PostPosted: Tue Oct 25, 2016 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That last msg is in my console log too.
Just be sure your USB connection is okay. If you have a lot of USB devices try to disconnect some?
rick
zenke
PostPosted: Tue Oct 25, 2016 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried every USB connector on my computer.
On omne it works after a fashion. It works after I have plugged it in. Then after that if I close the editor and reopen, it does not connect to the G2.
rick
PostPosted: Tue Oct 25, 2016 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't close the editor then Smile
What happens if you pull the usb plug an reinsert?
zenke
PostPosted: Wed Oct 26, 2016 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, Thats what I decided. Laughing
If I unplug and replug it seems to reconect. But thats a pain as the USBs are at the back of my machine which is under my table.
rick
PostPosted: Wed Oct 26, 2016 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Then unplug/replug at the back of the NM..?
Or get a usb extension cord and use that.
zenke
PostPosted: Thu Oct 27, 2016 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhh! Sometimes it just needs someone elses mind on things!! Duhh!
Extention lead I shall try. Thanks Ric.
Yep That seems to work . Nice one! I can live with that.
cheers
j
