Hacking a Casio CT360. Need schematic.
Page 1 of 1 [4 Posts]
KevinGlover
PostPosted: Tue Nov 01, 2016 9:32 pm    Post subject: Hacking a Casio CT360. Need schematic.
Subject description: Need a schematic for a Casio CT360
I am trying to find out if it's possible to hack a Casio CT-360 to get a CV and trigger output. However I would need a schematic to even see if it's possible. Does anyone know where I might find one? Has anyone ever tried this before or is it a lost cause?
Thanks,
-Kevin
PostPosted: Wed Nov 02, 2016 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
[removed due to personal reasons]
KevinGlover
PostPosted: Wed Nov 02, 2016 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tested the unit. Does not function. Only $10 at Goodwill. Can't complain.
Looking inside the keyboard appears to be some sort of diode matrix. I'll have to do some testing. Maybe build a demux or resistor ladder. It's for a modular anyway. Monophonic.
I'll check into circuit bending.
Thanks for the tip.
RF
Audio files: 28
PostPosted: Fri Nov 18, 2016 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I hacked up a CT-310 a while back - pulled the diode matrix, put in a resistor string and built a MFOS keyboard controller for use with it.
I don't get into to much detail but here is a link to the project.
http://www.sdiy.org/rfeng/various.html
Good luck.
www.sdiy.org/rfeng
