Posted: Wed May 23, 2012 12:53 pm Post subject:
SpringSim Subject description: Accutronics Digi-Log-Reverb Module
i made myself a simple reverb module built around an accutronics digi-log-reverb unit. the schematic is according to the datasheet, however, i changes some values to accomodate my synths audio levels.
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Wed May 23, 2012 7:53 pm Post subject:
Really nice! Inspiring too - I have an Acutronics reverb tank that's been gathering dust for years because I don't seem to have the time or motivation to adapt a circuit for it. Seeing this makes me think I might never get around to it, this being such a straightforward alternative.
Orsm as usual matthias
2 for a true stereo version would be nice
sign me up for 4 if you do produce a board
my current spring reverb is a box 2 feet square [the tank itself is huge] but then it is from the early 70's so this would be quite a bit more manageable panel wise _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any
just ordered 2 short and 2 long digi-log-reverb units from small bear
decided against getting the mediums as well not enough difference to warrant adding them in
should make for a nice module true stereo with a mix of short and long times available.
thanks matthias will be studying your schematic for the value changes
you used will save me a lot of time _________________ In an infinite universe one might very well
Hi Fonic,
Thank you for some great designs. I learn a lot!
I'm an electronics newbie, so please explain how the output opamps work in this circuit. Are they used as differential amps? How do they mix the dry and wet signals.
Izhar
