pt2399 question
Page 1 of 1 [6 Posts]
mike page
PostPosted: Sun Aug 20, 2017 9:11 am    Post subject: pt2399 question Reply with quote  Mark this post and the followings unread
Hiya, is it possible to modify the basic pt2399 delay circuit so that it only outputs the delayed signal. So just wet signal and just one repeat. Any thoughts?
Here is the basic schematic :
http://www.diyaudiocircuits.com/wp-content/uploads/2012/09/pt2399_echo_app_circuit.png
mike page
PostPosted: Sun Aug 20, 2017 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I worked it out. You can get the wet signal straight out of pin14.
wackelpeter
Audio files: 10
PostPosted: Sun Aug 20, 2017 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good that you find it yourself, but possibly this is useful for your needs too:
http://www.bernacomp.com/elec/og2/echo_delay.pdf
Scott Bernardi's VC Delay... you can easily follow the signal paths in the schematic and see how it works.
mike page
PostPosted: Mon Aug 21, 2017 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool thanx
PostPosted: Mon Jul 09, 2018 11:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
https://www.electrosmash.com/pt2399-analysis
my synth
MapacheRaper
PostPosted: Tue Jul 10, 2018 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering the same. Cool, i¨ll check it.
Regarding feedback: Im using a cheap chinese module with doesn´t implement feedback.
I have tried to mix the output into the input via a pot, but it seems is not working. Im quite newbie. Do you need opamps to get feedback, isn´t, or can be done directly in the standard datasheet circuit?
The electrosmash analisys states that you can get feedback via one pot and a cap between the 14-16 pins. Nice
