X-4046 VCO Page is Up
Page 7 of 7 [171 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
claudiodelcairo
PostPosted: Wed Apr 16, 2014 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
niiice!! Can you pm me the eagle files please?
PostPosted: Sun Apr 27, 2014 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="inlifeindeath"]
airfrankenstein wrote:
ive built 3 X-4046 VCOs and they're fantastic. Fonik offers great PCBs.
which i just re-designed. will offer 16HP eurorack circuit PCB + front panel components PCB (optional) + printed eurorack frontpanel (if enough interest) Very Happy
Tech Budday at Random*Source
paulstone
PostPosted: Sun Apr 27, 2014 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="fonik"]
wow Interest , hope soon Smile
PostPosted: Sun Apr 27, 2014 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
just have to order the prototypes...
piter_sensei
PostPosted: Thu May 15, 2014 10:19 am    Post subject: tempco question Reply with quote  Mark this post and the followings unread
hello,
i am from argentina, and quite new in this DIY world
my question is about the X4046 tempco resistor.
i cant find here the 2K tempco 3500ppm
but found a TTC 202 that is 4000ppm
i think the 2k2 value is not a problem for calibrate the scalling trime.
my question is about the conversion rate (4000 ppm) of ohms/c°
i test it, and with the tempco in thermal contact (in the middle) of my transistor pair (but not connected yet in the circuit), its go down in 60Ω by C° in the range between 20-25C°
my question of course is to ask if this TTC tempco is admissible in the Thomas Henry designs
thanks !!
Pedro
PostPosted: Thu May 15, 2014 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
the TTC 202 is a NTC (negativ going) while you need a PTC (positive going).
check these sellers: synthcube, thonk, bridechamber, or MFOS. they are specialized on synth DIY
piter_sensei
PostPosted: Fri May 16, 2014 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
ok thanks !!
PostPosted: Thu May 22, 2014 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
i finished the assembly of the prototype last night and it worked from the start.
now we have one PCB containing the actual circuitry of the complete VCO (waveshapers included), size 4in x 2.2in, and an additional adapter board for the for the front panel components (LFO mod/cap/LED included), size 4in x 3.1in eurorack form factor.
so now the actual VCO PCB is now smaller than just the core board from the 1st run, but is still providing MTA-100 connector footprints for easier manual wiring (if needed/wanted). and i now made a complex footprint to adapt a super matched pair (like the lm394) or your hand matched 3904 transistors.
now it is time to order a prototype frontpanel.
PostPosted: Tue Jul 08, 2014 3:07 am    Post subject:
Subject description: FYI
a new run of PCBs (and front panels) will be available soon:
http://electro-music.com/forum/post-401449.html#401449
Colonel Steel Lungs
PostPosted: Mon Aug 11, 2014 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I wish you would just label things on your schematics, Shoes. Lazy git.
msprigings
PostPosted: Thu Feb 26, 2015 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone had any issues with hot wave forms? I just tested my saw/tri and i'm getting around 15v p2p with the NXP 4046.
airfrankenstein
PostPosted: Thu Aug 27, 2015 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Could anyone suggest a cap value to make this VCo capable of LFO duties?
I'd like to put in a switch.
PostPosted: Tue Oct 20, 2015 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
that's what i did with the fonitronik PCB/Panel kit. you could even use a 2-pole switch and use the triangle output to drive a bi-color LED in LFO-mode.
i used 1uF NP for the LFO. you will even have an overlap, something i like to have.
http://www.synthdiy.fonitronik.de/forum/x4046-VCO_V2.pdf
airfrankenstein
PostPosted: Tue Oct 20, 2015 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I'm aware the feature is available on the new pcbs. I'm just going to try to squeeze in that option on V1, without the led.
Thanks
PostPosted: Tue Oct 20, 2015 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
i did a similiar retrofit for a customer on a 555VCO, using a sub-miniature switch:
Custom 555-VCO by Matthias Herrmann, on Flickr
wackelpeter
Audio files: 10
PostPosted: Tue Jan 26, 2016 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
just finished a 4046 VCO on stripboard.
Run's straight coming from the work bench, which is a bit unusual with my building skills... Very Happy
Tracking was a bit tricky thumleft ... had to swap the 4046 for some better results, but the rest is very fine...
will have to twaek the pwm a bit because when turning the pot fully cw or ccw i got either a + or - constant dc Signal... increasing the 330k should solve the Problem i guess....
what i have noticed is that my original triangle out on pin8 Shows some Spikes at the upper and bottom edges... 2-3 Volt more than the Signal itself... anyone with an idea to get rid of them?
well i'm glad with it and guess this week another 4046 will beborn on my workbench...
Thanks a lot Thomas for your very cool designs and your generosity to share your knowledge with the community.
thumleft
wackelpeter
Audio files: 10
PostPosted: Thu Aug 24, 2017 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know if i ever mentioned this before, but the Expo converter from the 4046 VCO works really well (and for me in an astonishing precise way) in the ASM1 VCO... have finished two of them and tuning was very easy, both oscillators track really close, so far my best result regarding tracking of a VCO...
Also i now used LF op amps in the Expo converter and thus slightly changed it a bit and added the positive and negative FM method as used on the buchla 258 VCO's.
On my two 4046 VCO it is limited somehow at higher range or at lower range which i had to make some compromises to handle both...
First of i think it has something to do with my CD4046, still managed it to get another brand, and also i finally decided to order a lot of polysterene caps which i can Exchange for the Polypropylene caps build in there, might improve things a bit i hope...
PostPosted: Thu Aug 24, 2017 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
you could subsitute polysterene with C0G ceramic. at reichelt they would be found under "NP0".
wackelpeter
Audio files: 10
PostPosted: Thu Aug 24, 2017 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry got it the wrong way around... too much poly's left me poly-confused Smile
After reading a guide, regarding caps and their use in audio circuits, i don't know exactly what web site it was, but it was from one of the more known guys (Marc Bareille perhaps) active in the DIY scene, who compared the different cap types and their use, giving a rough guide for their use.
For a long time i used polysterene (wima MKS) caps in most circuits, which seem not as useful in VCO's or VCF's. So from that list one of the closest replacements for silver mica were polypropylene caps (in my case Wima FKP2 and MKP2) from which i now ordered a few of some values to exchange them.
So those COG ceramics are better suited for audio applications than FKP2 or MKP2?
PostPosted: Thu Aug 24, 2017 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
WIMA MKS is polyester NOT polysterene.
polypropylen is good for s/h applications IIRC.
the best choice for timing caps is polysterene (i.e. styroflex) or ceramic C0G/NP0. polysterene is THE classic VCO cap, however, meanwhile the new C0G appeared and they have a much more civil footprint.
at least thats what i learned from different sources.
wackelpeter
Audio files: 10
PostPosted: Thu Aug 24, 2017 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes Matthias, you're right... i'm mixing up these different types of poly-whatever caps again...
Well next time i'll order some components i'll give those NPO-caps a try, perhaps the better alternative as MKP2 or FKP2 as they're cheaper and relatively small compared to those.
As per Wima web site those FKP2 are well suited for Timing, filter, s&h and audio circuits in general.
https://www.wima.de/de/produkte/filmfolien-kondensatoren-im-rm-7-5-15-mm/fkp-2/
Seems as i have to search for some more informations about those COG/NPO caps and were they better suit in audio circuits as polypropylene would do.
