today> Twyndyllyngs Live - special shelter in place episode experiment Chez Mosc
Suitcase lunetta tour/AD generator
Page 1 of 1 [5 Posts]
heim
PostPosted: Sun May 13, 2018 11:49 am    Post subject: Suitcase lunetta tour/AD generator Reply with quote  Mark this post and the followings unread
Hello,
I've been reading this forum for around a year and built my lunetta with your help, however I never got around to registering and posting something. Sooo, here's the suitcase lunetta, audio sample attached (EQ and a bit of reverb added).
I don't have exact schematics for it, but here are the resources I've used to build it, hope it will be useful to someone.
1) 4067 based 16 step sequencer.
Mostly relied on this schematic but used 4067 instead of 4051: https://hackaday.com/2015/02/23/logic-noise-the-switching-sequencer/. The outputs from 4040 to 4067 can be patched. Also there is a clock output to drive the second sequencer or something else. For 40106 range 20K pots and 1uF caps were used, it sounds a bit nicer that way.
2) 4051 based 8 step sequencer.
Same as 1)
3) Passive 6 channel mixer.
Nothing special about this one, just pots to output
4) 4 octave synth with vibrato
Pretty much relied on this schematic: http://www.electro-music.com/forum/topic-45583.html. Used 4068 instead of diodes to form AND gates. I recall reading somewhere that diode AND gates might be a bit unstable. For vibrato more simple circuit was used - filtered 40106 square wave to resemble a sine instead of generating an actual sine
5) 40106 x 6 oscillators
Just simple oscillators. 3 x audio range and 3 x LFO
6) R-2R ladder
Used this website to build it:http://castlerocktronics.com/modular.html. I thought that it could make cool waveshapes, but after building it I discovered that it does divides the frequency greatly, but it can be used to drive a VCO or modulate oscillators/sequencers.
7) 4015 shift register
Wires hooked up to an IC
Cool 4040 dividers
9) 4093 NAND gate
10) 4070 XOR gate
11) Audio to logic
This one is quite interesting. Got the idea from https://www.parasitstudio.se/building-blog/cmos-workshop-part-2-square-wave-fuzz. It amplifies signals to logic levels and the cleans up the wave with 40106.
12) 40106 x 6 oscillators
Same as 5) but added option to modulate the waves through a cap or a pot. There's a nice video about it on youtube: https://www.youtube.com/watch?v=FaoJaLmZaL4
Found another suitcase near the dumpster outside my house, so I'll make another one Very Happy
The actual question I have is regarding attack/decay generation for a sequencer. It has a clock output, so I think I could use it as gate/trigger (I still don't fully understand this) for VCA, but the schematics are a bit too difficult for me. Are there any resources for this or simpler schematics?
020_1.mp3
 Filename:  020_1.mp3
 Filesize:  1.7 MB
 Downloaded:  221 Time(s)
Steveg
PostPosted: Sun May 13, 2018 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well done. A very nice machine.
Audio files: 644
PostPosted: Mon May 14, 2018 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent build with a nice selection of modules. I like that you put a 4 octave synth with so many buttons in there. Laughing
Your post gave me a boost to continue with my own lunetta in a suitcase.
Do I understand it correct that you want to use an AD generator + a VCA clocked by the sequencer ?
If you a refering to the sequencer from hackaday than you can use any output from the 4040 but most likely
you want to use output Q4, at least if you connected it in the same way.
If you only want to use squarewaves the VCA part can be very simple and an AD generator can be built easy too with a 555.
Audio files: 156
PostPosted: Mon May 14, 2018 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice Lunetta. Congratulations...
I like the sound of your sample recording too.
Thanks for finally signing up and posting. welcome
hexagon5un
PostPosted: Tue May 15, 2018 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic work!
