 Forum index » DIY Hardware and Software » PAIA Equipment
PAIA2720-3B VC Bandpass Filter_Augmentations
Page 1 of 1 [20 Posts]
gasboss775
PostPosted: Tue May 16, 2017 6:40 am    Post subject: PAIA2720-3B VC Bandpass Filter_Augmentations Reply with quote  Mark this post and the followings unread
I tried out the PAIA 2720-3B VC Bandpass Filter on the breadboard. I wasn't initially that impressed with its range. However I swapped the diode for a red led and drove it from an exponential current source, the result was a great increase in the range of the filter. I also changed the way in which the Q control was implemented, resulting in, in my opinion a more natural control contour.
I also made a second version with a simpler current source using just one NPN transistor. The results were still very impressive.
The most interesting characteristic of these filters is the way they behave when overdriven. With high Q settings, the LED becomes modulated by the very signal that it is controlling and things freak out somewhat, the LED flickers too in response to the large signal swing!
The original is included for comparison.
 Filesize:  288.89 KB
 Viewed:  444 Time(s)
 Filesize:  212.14 KB
 Viewed:  421 Time(s)
 Filesize:  11.33 KB
 Viewed:  387 Time(s)
gasboss775
PostPosted: Wed May 17, 2017 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried out the PAiA 2720-3L Lowpass filter. Again it worked better with LEDs instead of diodes and a current source to drive the LEDs. I chained two Lowpass filter sections together to make a 4 pole filter. It was quite good but would really benefit from having a Q / resonance control. I'm going to have to figure out if this can be done.
gasboss775
PostPosted: Sat May 20, 2017 5:20 am    Post subject: Better Current Source Version Reply with quote  Mark this post and the followings unread
This version of the 2720-3B bandpass filter has a linear current source that doesn't have any tempco problems.
 Filesize:  93.87 KB
 Viewed:  402 Time(s)
gasboss775
PostPosted: Sun May 21, 2017 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I was just trying out the circuit from my last post again and it would seem that 68K is a better choice for R12 as it allows the filter to be completely closed.
I suspect that there might need to be a bit of experimentation with some of the resistor values to accommodate different LED's. Specifically, R9 & R12.
gasboss775
PostPosted: Sun May 21, 2017 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I built 2 of the PAiA 2720-3B bandpass VCFs and designed a little two transistor mixer and output stage with 10 V peak to peak maximum output.
The sinewave generators represent the 2 filters, the 10K resistor on the right represents the output load.
 Filesize:  48.18 KB
 Viewed:  347 Time(s)
n.d
PostPosted: Fri Feb 16, 2018 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work!
gasboss775
PostPosted: Fri Mar 09, 2018 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
n.d wrote:
Nice work!
Thanks dude.
I have experienced some problems with instability ( it bursts into oscillation ) that seem to be somewhat related to circuit layout ( I've only ever built it on a breadboard )
I did find that putting a 100n ( 0.1uF ) capacitor between the collector or Q2 and ground helped a bit. Does anyone else have any suggestions about making this behave. I was thinking of using either an FET optocoupler or a vactrol instead of the diode to tune the filter in order to avoid the circuit using the same ground as the control signal.
Fernando
PostPosted: Mon Aug 27, 2018 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice gasboss!
I always think about trying the most simple PAiA circuits.
Well for the twin T filter (2720-3b) I'd try with a photocell instead of the diode and a circuit to control the LED. Or a real vactrol instead of a DIY one. But DIY you can use a more adequate range for the photocell and have less work fine-tuning it's right resistance range.
There are many schematics for vactrol CV around from other circuits (Buchla LPG, etc.) but I'd try something much simpler first, the simplest possible.
Try this: http://thesquarewaveparade.com/images/VtoR.jpg (second option, with offset)
And read here: http://www.electro-music.com/forum/topic-37628.html
Fer
gasboss775
PostPosted: Mon Sep 17, 2018 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Fernando wrote:
very nice gasboss!
Thanks for the complement Fernando!
I have several vactrols and have been meaning to try them out in this circuit. Using a diode or LED have their own charms due to the distortion generated when the filter is driven with a strong signal. I do like vactrol based filters though, they have a dynamic character of their own.
Fernando
PostPosted: Mon Sep 17, 2018 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
gasboss775 wrote:
Using a diode or LED have their own charms due to the distortion generated when the filter is driven with a strong signal..
that's interesting
I would try with a chain of Ge diodes then
Fer
gasboss775
PostPosted: Tue Sep 18, 2018 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, Ge diodes sound like a good idea, never tried them at the time.
Audio files: 35
PostPosted: Tue Sep 18, 2018 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
My experience of clipping diodes in pedals is that Ge diodes have a "softer" sound than Si diodes. You need a couple in series to match the Fv of silicon, though.
gasboss775
PostPosted: Thu Sep 27, 2018 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Today I tried Ge diodes with a similar filter circuit and it did sound more agreeable ( less harsh than the Si diode ), I also tried an led but I think it sounded worse than the silicon diode !
Fernando
PostPosted: Mon Oct 01, 2018 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
but in the same position as in the PAiA band pass?
I mean, as the variable resistance to ground at the bottom of the twin T?
Fer
gasboss775
PostPosted: Wed Oct 03, 2018 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes the diode was in the same position as with the PAiA circuit.
Audio files: 35
PostPosted: Wed Oct 03, 2018 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
LEDs have a fairly high Fv compared to silicon or Ge, they're pretty harsh in pedals, too Smile translates to high levels before clipping.
cslammy
PostPosted: Fri Nov 30, 2018 9:12 am    Post subject: Re: PAIA2720-3B VC Bandpass Filter_Augmentations Reply with quote  Mark this post and the followings unread
Gasboss, what power are you using for V++ and V--? +/- 15V?
please visit my AUDIODIWHY blog and website
gasboss775
PostPosted: Sun Dec 02, 2018 2:26 pm    Post subject: Re: PAIA2720-3B VC Bandpass Filter_Augmentations Reply with quote  Mark this post and the followings unread
Gasboss,j what power are you using for V++ and V--? +/- 15V?
The circuit works from a single +Ve supply rail +12 to + 15 V, 15 would provide more dynamic range for the signal.
vladosh
Audio files: 12
PostPosted: Fri Dec 07, 2018 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's some PCB layout for this ,if that's ok . I didn't made the add-on mixer ,just the last linear response version ,wanna try this version , have built this filter once earlier as the original on 18V ,PCB is 70x100mm
 Filesize:  496.74 KB
 Viewed:  102 Time(s)
 Filesize:  19.19 KB
 Viewed:  97 Time(s)
danielfiction
PostPosted: Wed Jan 09, 2019 12:53 pm    Post subject: notch? Reply with quote  Mark this post and the followings unread
i'm really interested in this filter. i'm going to build it.
but what about modifying it for "notch", aka, band stop output? how would you go about that?
daniel
