IGR
Posted: Thu Sep 06, 2018 4:11 am Post subject:
Pulse ignorer/divider Subject description: Question. |
Does anyone know how to simply filter out adjustable number of pulses from the clock? For example: first gets through, the second to tenth are ignored, the eleventh passes again, and again and again..I think about monostable with variable pulse lenght and behind it clocked NAND gate.
It is about not to make it complicated, I need four of these circuits.Thanks for your inspiration. |
gabbagabi
Joined: Nov 29, 2008 Posts: 651 Location: Berlin by n8
Posted: Thu Sep 06, 2018 5:16 am Post subject:
4017?
only Q0 is used for driving futher circuitry? |
IGR
Posted: Thu Sep 06, 2018 5:27 am Post subject:
I wrote it inaccurately, with the word "adjustable" I meant not switchable, simply a pot. I know that the monostable time constant setting is only valid for the actual clock speed, and the division ratio changes as the clock tempo changes.
Something similar see:https://youtu.be/cmVvdpp1QX0 |
gabbagabi
Audio files: 705
Posted: Thu Sep 06, 2018 7:00 am Post subject:
Re: Pulse ignorer/divider Subject description: Question. |
IGR wrote: | I think about monostable with variable pulse lenght and behind it clocked NAND gate. |
yeah, something like that but probably with a flip/flop instead of a NAND.
Does the pulsewidth of the output signal matter ?
@g.gabba that's a very neat idea and it doesn't need any adjustment if the frequency changes
(maybe an extra AND gate at the output or something else so it can produce multiple pulses) _________________ "My perf, it's full of holes!"
IGR
Posted: Thu Sep 06, 2018 7:13 am Post subject:
Pulse length ideally trigger/ ~5ms, but I would get it from the leading edge. |
IGR
Posted: Thu Sep 06, 2018 7:32 am Post subject:
@g.gabba Elegant solution, thanks. I´ll use one comparator for reseting the counter, to shorten the cycle, maybe better a switch with fixed resistors than pot. |
gabbagabi
IGR
Posted: Sat Sep 08, 2018 1:35 am Post subject:
Thanks for your engineering exercises. But I wrote Blödsinn, to shorten the cycle I need only binary state of the counter, it is not necessary to go back in the natural numbers. But you are thinking great. I am now obsessed with a pseudo-random sequencer reset. I have a four-step CV 4017 sequencer (outputs 1,3,5,7 reset by AND select of the outputs from the next 4017 which receives the clock from the XNOR gate.) To XNOR go bits 1 and 4 of 4024 with the same clock as the 4-track CV. |
