cslammy
gabbagabi
Joined: Nov 29, 2008 Posts: 651 Location: Berlin by n8
Posted: Wed Nov 07, 2018 10:18 am Post subject:
nice,
when ur want to use this also for protecting cmos of negative voltages, may diodes on the output would protect even more?
or have two outputs per channel, one with and one without diode protection.
cu |
cslammy
Posted: Wed Nov 07, 2018 11:31 am Post subject:
Good point. To protect vs. negative voltages, just thinking out loud: perhaps you could power the board from GND to V++ instead of V++ and V--? And maybe use Rail to rail quad op amps vs. say TL074?
Suggestions for negative protection are indeed needed--what does the group think is the best way? Link anyone?
This certainly comes up with getting signals into MPU like Arduino. You don't want high current V- for that. Zeners? 4148's? Something else?
I have seen a lot of circuit clamp fragments but don't know what works best.
Thanks. _________________ Visit my AUDIODIWHY blog and website |
gabbagabi
cslammy
Posted: Wed Nov 07, 2018 12:26 pm Post subject:
Thanks! Good suggestion.
Q: Do you take a diode drop doing that? 700mV or so? I thought so....
For many applications that won't matter, but sometimes it will. Assuming we do see that, I'd need the voltages pass through unencumbered. Same for signals coming into the buffer.
I am trying to figure this out, since I will be using 4066 and 4053 on an upcoming project and the voltages are driving some sensitive gear. _________________ Visit my AUDIODIWHY blog and website |
gabbagabi
Posted: Thu Nov 08, 2018 11:12 am Post subject:
dunno but may the precisicion-rectifier could help you?
there u dont have to deal with the voltage drop.
as an example i did a simulation with 1Vpp input.
if so, than moving the offset to the first stage would make sense.
Description: |
Filesize: |
69.56 KB |
Viewed: |
325 Time(s) |
Description: |
Filesize: |
49.35 KB |
Viewed: |
355 Time(s) |
cslammy
MapacheRaper
Posted: Thu Nov 08, 2018 7:38 pm Post subject:
Hey Charlie, I have no idea on how to protect it, but I have recently discover your audiowhy blog and Im totally addicted to it... I just had to say it loud.
gabbagabi
Posted: Thu Nov 08, 2018 10:20 pm Post subject:
i know almost nothing about zeners
the circuit is really called Precision_rectifier:
https://en.wikipedia.org/wiki/Precision_rectifier
it is also used as SAW2TRI converter, eg in the Yusynth VCO and LFO |
cslammy
Posted: Fri Nov 09, 2018 8:56 am Post subject:
MapacheRaper wrote: | Hey Charlie, I have no idea on how to protect it, but I have recently discover your audiowhy blog and Im totally addicted to it... I just had to say it loud.
Thanks so much Mapache. I really enjoy writing it. _________________ Visit my AUDIODIWHY blog and website |
cslammy
Posted: Fri Nov 09, 2018 9:00 am Post subject:
Ha! Thanks gabba, great link! I will try to breadboard it this weekend. _________________ Visit my AUDIODIWHY blog and website |
cslammy
gabbagabi
