  PHOBoS presents: music from project "droning" by Lougi Verona
Digital Pot triangle wave generator
Page 1 of 1 [10 Posts]
mike page
PostPosted: Sat Nov 24, 2018 10:53 am    Post subject: Digital Pot triangle wave generator Reply with quote  Mark this post and the followings unread
maybe one of these: https://www.analog.com/media/en/technical-documentation/data-sheets/AD5220.pdf
driven by a 4060 with the /by 256 toggling the up/down
then just use it as a voltage divider.
not sure if they can go fast enough for audio rate though...
Audio files: 27
PostPosted: Sat Nov 24, 2018 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fastest clock frequency is 20MHz, so it will take about 13usec to go from 0 to 256 that is about 77kHz.
So clocking is no problem, if the wiper will follow with this clockspeed depends (also) on the resistance of the digital pot, where lower values are the fastest.
I guess you have to try.
By feeding the A input with a buffered AD or ADSR signal, you don’t need a VCA, although I suspect bleeding of the clock signal when the ADSR is at 0 volt.
my synth
mike page
PostPosted: Sat Nov 24, 2018 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good point!
would be interested to chuck some other junk at the up/down pin to get different waveshapes
Audio files: 27
PostPosted: Sat Nov 24, 2018 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Set the up/down input to up and keep counting, you get a saw shape, set it to down and you have a backwards saw.
Ow, just noticed 128 steps Rolling Eyes
my synth
piedwagtail
PostPosted: Mon Nov 26, 2018 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
off the top of my head(as usual)
This looks like part of an interesting pitch quantizer with a paralleled gating system to cut out increments.
R
Audio files: 27
PostPosted: Mon Nov 26, 2018 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
This one only counts up or down, not good for quantising
my synth
piedwagtail
PostPosted: Mon Nov 26, 2018 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, stick various pulses into clk and direction, in any relationship. Then use another pulse to sample and hold the output of W. Use A and B to figure range. Lunetta to pitch CV.
I'm pointing to a composition device using pulses rather than your or the OPs conception of using it directly as a wave provider.
Farnell seem to have the best prices, especially for SOICs.
For Moonbase, there's the AD5222.
R
Audio files: 624
PostPosted: Mon Nov 26, 2018 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
oh interesting, I didn't realize it has the counter built in untill I checked the datasheet.
hmm, NANDulators connected to the inputs, 'pots' connected to a NANDulator ? Twisted Evil
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
piedwagtail
PostPosted: Mon Nov 26, 2018 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
oh interesting, I didn't realize it has the counter built in until I checked the datasheet
Yes, Mike seems to have brought to our attention to a very interesting device.
I look forward to seeing where both the waveshaping and compositional routes can take us.
R
Audio files: 27
PostPosted: Mon Nov 26, 2018 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Carefull with lunetta or nandulator, since the absolute max voltage for this device is 7 volts.
my synth
