OSC OSCar synth not starting
Page 1 of 1 [4 Posts]
wahee
PostPosted: Sun Jan 27, 2019 2:58 pm    Post subject: OSC OSCar synth not starting Reply with quote  Mark this post and the followings unread
My rather nice OSCar synth started to make some strange noises whilst on and then died.
I just get all the octave LED's lit up but most times nothing.
If I use the keyboard every 8 note makes an octave LED light up and the space button will light a LED also.
No sound
So I have:
checked the +5/-5v power rails. All good
checked battery voltage OK at 3.4v
checked the keyboard and power ribbon cables for continuity, all OK
Rewired the control board and voice board interconnects with new quality connectors
checked the continuity of sockets with the piggy back MIDI board, all OK
checked practically all the 40 and 74 logic IC's with a tester.
Swapped out the 6116 RAM x2 for known good, no change.
checked the clock on the ADC and there is a square wave present on the scope, so seems OK
but I still have no luck
I have checked the Z80 with a scope and it seems lifeless,so swapped it for a known good. But again no luck.
I suspect the reset circuit. Should I see something on the output of this circuit when the synth is first powered up?
is there anything else I can try as this synth seems relatively simple but has thrown me.
Embarassed
Regebro
PostPosted: Thu Jan 16, 2020 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Late answer, but that's exactly how they behave when the battery is dead.
Regebro
PostPosted: Fri Jan 24, 2020 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
To be clear, they behave like this even AFTER the battery has been recharged/reset. Booting multiple times usually gets by pure luck, to a place where LEDs blink. The fastest thing to do then is to load a memory dump over MIDI.
You can also press the "Panel" button, and then twist every single knob. This usually gets things into a more reasonable mode. Then save the current settings to every single memory.
Reboot, and you should be in business. Smile
However, I read a few days ago, that if it continues to not boot properly, then yes i can be the reset circuit, and the solution is apparently to pull extra power lines directly, which seems like a hack...
citygas
PostPosted: Sat Apr 04, 2020 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Long time gone..
Any joy?
I just fixed my deloren synth..hope your one is going again, so bad yet so good design
