Yusynth VCLFO2 problem
Page 1 of 1 [7 Posts]
yoopee
PostPosted: Fri Jan 24, 2014 2:38 pm    Post subject: Yusynth VCLFO2 problem Reply with quote  Mark this post and the followings unread
hello,
thanks for this wonderful modular diy project.
I'm building few of this modules, now trying to trim the VC LFO2 module.
The pulse and sawtooth waveforms are ok, but triangle and sinus are distorted as you can see on attached screenshots.
I tried to change U3, checked R19,R20,R21,R22,R23,R24, diodes D1,D2
and everything looks ok...
any suggestions what else to check?
thank you
yoopee
PostPosted: Fri Jan 24, 2014 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
uh, I've attached wrong screenshots,these are correct
 Filesize:  18.65 KB
 Viewed:  572 Time(s)
 Filesize:  18.25 KB
 Viewed:  602 Time(s)
marfoski
PostPosted: Fri Jan 24, 2014 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a known quirk of this circuit, something you have to live with, in a sense.
Take a look at this : http://electro-music.com/forum/viewtopic.php?highlight=lfo&t=44023
yoopee
PostPosted: Sat Jan 25, 2014 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you! So my VCLFO is trimmed okay...
kupfer_m
PostPosted: Sat Aug 02, 2014 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
So there's nothing that can be done to get rid of these spikes?
gibrancurtiss
PostPosted: Sat Apr 08, 2017 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
PLease, check this:
http://electro-music.com/forum/topic-44023.html&postorder=asc&highlight=lfo&start=25
PostPosted: Mon Apr 06, 2020 10:48 am    Post subject: Spikes on Yusynth VCLFO solved! Reply with quote  Mark this post and the followings unread
The problem turned out to be confusion about the value of C8.
C8 is in the feedback loop of IC3c and, as such, implements a low-pass filter.
Increasing the value of C8 decreases the voltage spike. If C8 is too large, part of the desired waveform gets filtered* and if C8 is too small, the spike passes through.
(* -- if C8 is way too large, the amplitude of the triangle and sawtooth outputs are reduced. All this is is a fixed low pass filter -- with a low enough cutoff frequency, nothing will pass!)
When I replaced C8 with a 4700p (4n7 or .0047u) Polyester Film Capacitor, the spike was filtered out. On the very highest frequency the corners of the triangle wave are slightly rounded -- shouldn't really be an audible issue, though.
The confusion is that C8 is specified as a:
100nf on the parts list,
47p on the parts layout
1n on the schematic
I originally used a 47p for C8 which was too small a value. I experimented with different values and arrived at using the 4700p cap.
The current stay-at-home order (due to the Coronavirus) has given me time to revisit some old problems that had remained unsolved.
I know others have had this problem and hope that this solution helps.
