vocal sounds on NM
Page 1 of 1 [6 Posts]
CJ MMx
PostPosted: Wed Oct 05, 2005 1:54 pm    Post subject: vocal sounds on NM Reply with quote  Mark this post and the followings unread
Hi everyone! I'm interesting is it possible to make sound on NM G1 vocoder like this http://www.monomachine.com/sound/soundfiles/vo/DE-TheFamily.mp3
Dark Psychedelic Emotions
DrJustice
PostPosted: Wed Oct 05, 2005 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi CJ!
The NM can do much better than that. Instead of using the vocoder module, you'd be better off using the special vocal filters that has ready made responses for the A,E,I,O,U and Y formants. Using these and e.g. some sequencer modules and a few other things you can make quite advanced speech synthesis patches.
DJ
X-Electric
PostPosted: Fri Oct 07, 2005 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactely. The sound preview You posted was not made with vocoder. Check out this tutorial:
http://www.cim.mcgill.ca/~clark/nordmodularbook/nm_speech.html#speech
CJ MMx
PostPosted: Fri Oct 07, 2005 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 X-Electric: I know that Monomachine synthesize such sounds itself. I just want to know is it possible to do the same sound using NM vocoder.
Kassen
PostPosted: Fri Oct 07, 2005 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suppose that with some fairly elaborate controll structures you could force the vocoder to do that but that's realy ineficient and frankly too much work. You are much better off either taking the vocal filter or looking up a table of the proper formants and synthesising them on your own.
The vocal filter is closer to what the monomachine probably does anyway.
Kassen
OAO3
PostPosted: Fri Oct 07, 2005 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, what those guys said. that sample was actually pretty weak compared to what i've heard the nord do! here are some links to the archive that you might want to check out...
vox
words
hehe, i haven't check out that part of the archives in a while.... whoever made "gayporntop" and "gaypornbottom".... GENIUS! now THAT is what the nord was made to do!!!
music: teamabunai.org/oao
everything else: teamabunai.org
