EraSer
Posted: Thu Sep 28, 2006 11:26 am Post subject:
control SL with stylus type keypad |
Do you know if a stylus type keypad can be a good controller for SL?I think 1octave keyb is good enough for me.Do you know if it can run with 9V ? Have someone use it? |
sohcahtoa
Posted: Thu Sep 28, 2006 7:38 pm Post subject:
I would work great! |
Wild Zebra
Posted: Fri Sep 29, 2006 6:19 am Post subject:
Alright I'm gonna get right to the point. What is a "stylus" keyboard? I understand keyboard. _________________ "your stripes are killer bro" |
EraSer
Posted: Fri Sep 29, 2006 7:09 am Post subject:
Wild Zebra wrote: | Alright I'm gonna get right to the point. What is a "stylus" keyboard? I understand keyboard. |
"Stylus" maybe is not correct at all: it means stylophone keyboard. |
Audio files: 278
Posted: Fri Sep 29, 2006 7:15 am Post subject:
A stylophone is fun !
It's more fun even to have two styluses, styliea, or whatever one writes for that. It's monophonic, but holding one at a fixed position and moving the other around & lifting it occasionally allows for really fast crazy stuff
(that is if the design allows for it and gives the lowest (or highest) note prioriity). _________________ Jan
Wild Zebra
Posted: Fri Sep 29, 2006 8:19 am Post subject:
Thats what I was kinda thinking I've just never seen one. So can you implement this circuit with momentary switches? Say connect one lug of the switch to the assigned number and daisy chain the other lugs to the resistor (r1 I think) that corresponds to the stylus? _________________ "your stripes are killer bro" |
Audio files: 278
Posted: Fri Sep 29, 2006 9:10 am Post subject:
The idea is to have no keys or switches but a PCB with contact areas that you touch with a stylus.
The PCB areas are connected with the taps of a resistor chain and the stylus picks up the voltage to control your osc, or whatever it is you want to control. The resistor chain can be the same as for other momophonic analog synths, but it's not really easy to obtain a gate ir trigger signal ("key" pressed indication).
It would be ideal to have the contact areas covered with something more resistive to wear and oxidation than copper, nickel seems to be good for that. But the one I used to have was just copper and I remember having to polish it a bit every now and then. _________________ Jan
EraSer
Posted: Fri Sep 29, 2006 10:24 am Post subject:
According to Ray you would hook the keys to the inputs of the CD4067 (the pin 1s of all of the switches) and connect the stylus to pin 1 of R1. Touching the keys with the stylus is just like closing one of the switches shown in the schematic. I see in the schematic that it runs on 5 volts and the gate is amplified to 12 volts.Could I use 9 volts battery instead of 12Volts ? |
Wild Zebra
Posted: Fri Sep 29, 2006 10:36 am Post subject:
Sorry balance I don't know that. Maybe if no one answers you could PM Ray adhdboy or U K, dnny, someone with a lot more knowlwdge than I. _________________ "your stripes are killer bro" |
Posted: Fri Sep 29, 2006 1:19 pm Post subject:
it should work, i think. ray states that his system needs a +12V gate, which is very high and uncommon. either 9V+ would be high so you should be fine with that, using two 9V batteries as for the soundlab...
matthias |
Wild Zebra
Posted: Sat Sep 30, 2006 7:24 am Post subject:
Sorry I keep stealin your thread balance, but while we're on the subject. Whats up with the 5V+. I'm unfamiliar with this stuff. I'm still a one 9v battery guy. Well except the SL. _________________ "your stripes are killer bro" |
Posted: Sat Sep 30, 2006 8:58 am Post subject:
Quote: | Sorry I keep stealin your thread balance, but while we're on the subject. Whats up with the 5V+. I'm unfamiliar with this stuff. I'm still a one 9v battery guy. Well except the SL. |
the hex flip-flop 74hc174 must not have more than 5V+... (thats the "hc" for in the parts name, i think).
matthias |
Posted: Sun Oct 01, 2006 6:47 am Post subject:
Why don't you build the single bus to CV/Gate/Trigger and just use it as a stylus type of controller. It still uses a chain of resistors which are shorted to a single connection (which is what the stylus type does) but it produces CV, Gate and Trigger and includes Portamento. It runs off +/-9V exactly the same as the SoundLab, and I've already done a stripboard layout for it, which I've built and runs perfectly.
http://www.musicfromouterspace.com/analogsynth/keybrdcontroller.html _________________ What makes a space ours, is what we put there, and what we do there. |
Wild Zebra
Posted: Mon Oct 02, 2006 7:46 am Post subject:
I'm still having trouble wrapping my tiny little brain around this. But, in UK's suggestion, the part I 'm having trouble with is the Keyboard. So I just basically need a series of switches, keys, buttons, etc, one lug is the bus chain and the other lug is the resistor chain. Right? I'm far from making a keyboard but I have seen some cool one octave keyboards that look like normally closed buttons. Is this the type of circuit you could use. Or like when y'all all tear apart an old keyboard? Thanks _________________ "your stripes are killer bro" |
Posted: Mon Oct 02, 2006 8:14 am Post subject:
One side of the connection is the "single bus";
In an old organ this is the piece if nickel plated brass which all of the key springs push onto.
In a stylophone it is the tip of the stylus, some use a ball point pen with a blob of solder on the end.
If you use momentary switches, it is the connection which goes to one side of every switch.
The other side of the connection is one of many points along the resistor chain;
On the old organ each point has a spring soldered to it.
On the stylophone each point is a pad of copper on the PCB.
With the switches, each point goes to the other side of each switch. _________________ What makes a space ours, is what we put there, and what we do there. |
Wild Zebra
Posted: Mon Oct 02, 2006 9:01 am Post subject:
THANKS! _________________ "your stripes are killer bro" |
EraSer
Posted: Fri Oct 13, 2006 12:54 am Post subject:
Have I to do the 1v/oct scale mod to use this type of keyboard |
Posted: Fri Oct 13, 2006 1:20 am Post subject:
you don't have to, but it's highly recommended: unless you've done this mod you're not able to get both VCOs in track. they will respond differently to the incoming control voltages. you will not be able to play a tuned SL, an octave on the keyboard will not be an octave on the SL and even worse different on both VCOs...
matthias |
