Sw-Michael
Posted: Thu Aug 17, 2006 1:10 pm Post subject:
New Micro Modular, Noodles and more |
Hi everyone!
Received my Micro Modular today. Very happy, have been looking for one for a couple of months. Currently browsing the patch archieve.
I'm especially interested in generative patches, evolving soundscapes, what you people call noodles. Unfortunately, there doesn't seem to be a patch category for that. Anyone care to recommend a few favorites?
A question: When I load some patches, I get an error message: "Module already exists". Huh?
A tip: I didn't manage to the get the editor working until I set in Windows NT compatibility mode. I saw some else recommend Win98, but that didn't work for me. I'm on a PC running XP SP2. |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Thu Aug 17, 2006 5:59 pm Post subject:
A while ago I put up a bit of "Nord Modular Noodle History" for my Noodle Radio project. That history has some names and patches (for NM Classic and some for G2) in it, so it might serve as a starting point maybe. Direct link : http://84.84.192.7/jan/nr/info/forums.html .
Hope it will get you going
edit : I just noticed that the server is not properly configured for pch files (they open as text files here when I click on 'm), but when you use "save as" from the right mouse button popup menu it seems to result into properly saved patches - for Mozilla that is. _________________ Jan
Ivity
Joined: Dec 29, 2005 Posts: 233 Location: Moscow, Russia
G2 patch files: 57
Posted: Tue Oct 10, 2006 9:32 pm Post subject:
Re: New Micro Modular, Noodles and more |
Sw-Michael wrote: | A question: When I load some patches, I get an error message: "Module already exists". Huh? |
I have the same strange warnings
Some of the patches opens correctly, and some of them opens with this strange messages _________________ Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html |
kvnvk
Posted: Wed Oct 11, 2006 6:01 am Post subject:
I've gotten the same message when opening certain NM1 patches, what I noticed is that some of the modules aren't actually connected even though the patch cords are present. all I do is make new connections between those unconnected modules and save. sometimes it can get quite involved especially if there are a few dozen unconnected patch cords, but this process has worked for me without a problem... running Windows XP on a Compaq Presario 2100 in case anyone needed to know. |
kvnvk
Posted: Wed Oct 11, 2006 6:18 am Post subject:
in this screen shot you'll notice the connections from the LFOslvD1 to the two pitch inputs on MasterOsc1 are not "filled in" like all the others... |
Ivity
G2 patch files: 57
Posted: Wed Oct 11, 2006 6:49 am Post subject:
kvnvk wrote: | I've gotten the same message when opening certain NM1 patches, what I noticed is that some of the modules aren't actually connected even though the patch cords are present. |
The same thing on my NM _________________ Igor
kvnvk
Posted: Wed Oct 11, 2006 8:29 am Post subject:
as I said, just re-patch those connections... don't worry if you can't delete the ones already there, once you finish and save, the extra, unconnected patchcords will disappear. |
Audio files: 278
Posted: Wed Oct 11, 2006 1:07 pm Post subject:
kvnvk wrote: | Iwhat I noticed is that some of the modules aren't actually connected even though the patch cords are present. |
Interesting, could you post such a patch ? I'd like to have a look at it. _________________ Jan
kvnvk
Posted: Wed Oct 11, 2006 5:49 pm Post subject:
as a screenshot, which I did above? or the actual patch itself? |
Audio files: 278
Posted: Thu Oct 12, 2006 2:18 am Post subject:
I meant the pch file, had a look at the screen shot, byt wondered what might have happened to the pch file that could have caused this. So if you still have it .. the unfixed patch file. _________________ Jan
kvnvk
Posted: Thu Oct 12, 2006 7:26 am Post subject:
actually, I already fixed it...
the patches I had problems with I had downloaded from the Nord Modular archives earlier this year... I'll check if I re-download that particular patch whether or not I have the same problem with it. if so, I'll try to post it here for you to check. |
Audio files: 278
kvnvk
Posted: Fri Oct 13, 2006 7:50 am Post subject:
funny thing is I downloaded that same patch again and it was perfectly fine... |
kvnvk
Audio files: 278
Posted: Fri Oct 13, 2006 11:53 am Post subject:
Yes ! I can now reproduce the problem.
And it's obvious what is wrong with the file, the contents are repeated two times (can be checked with a text editor, search for the word "header").
The weird thing though is that when I download the patch from the archive it is OK ...
Hmm, question now is ... is it your browser or is it the server doing the spurious stuff ... some others had this as well, which seems to point to the server. Going to do some tests on this later. Especially as some of the HTML in Wout's archive is doubled as well (for unknown reasons as well).
Thanks for posting the patch ! _________________ Jan
Audio files: 278
Posted: Fri Oct 13, 2006 11:55 am Post subject:
I'd like people having this kind of problem with patches from the archive to report their computer type and browser brand, maybe that gives a clue.
I've seen some Windows passing by, no browsers yet.
Edit : I've just tried over 100 patches, which is not a large portion of the 24000+, but didn't have any problems (win xp sp2 mozilla). _________________ Jan
kvnvk
Posted: Fri Oct 13, 2006 10:01 pm Post subject:
using a four year old compaq presario 2100 laptop running windows xp w/ sp2 and internet explorer. |
Ivity
G2 patch files: 57
Audio files: 278
Posted: Sat Oct 14, 2006 1:36 pm Post subject:
I don't see a pattern here, maybe time will sort it out.
Thank you for the time taken to give feedback on this ! _________________ Jan
