droffset
Joined: Feb 02, 2009 Posts: 466 Location: new zealand
Posted: Tue Apr 06, 2010 8:30 pm Post subject:
SN voice wiring |
Hello, I'm really close to being done with the SN voice but have a small query. The Coarse, Fine and Noise Init pots all need +- 15v connections but only one of them references J1 connections to do it. Can I use the same for all three and star out to them from that one location?
Cheers, can't wait to turn this on and hopefully not burn the house down. _________________ ==================
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes. |
Joined: May 16, 2005 Posts: 8673 Location: Birmingham, England, UK
Posted: Wed Apr 07, 2010 7:26 am Post subject:
Have you decided on wether you are going to have a 7 octave range, or PWM?
My board is also pretty much there (just need to solder a couple more caps, and put the main chip in). But I've been pondering the above. Have left out two resistors on the board.
I asked the same question elsewhere, but no one answered. Damn this forum!  _________________ ACHTUNG!
RF
Joined: Mar 23, 2007 Posts: 1459 Location: Northern Minnesota, USA
Audio files: 29
Posted: Wed Apr 07, 2010 7:52 am Post subject:
| v-un-v wrote: | | Have you decided on wether you are going to have a 7 octave range, or PWM? |
I have not even started on my board - which has sat far too long... I didn't even know there was a choice like that to be made.
Be that as it may... for my uses PWM would be the choice.
| v-un-v wrote: |
I asked the same question elsewhere, but no one answered. Damn this forum!  |
lol... unresolved issues, v-un-v?
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Posted: Wed Apr 07, 2010 7:57 am Post subject:
droffset
Posted: Wed Apr 07, 2010 11:45 am Post subject:
Hmm, I clearly didn't read enough in the instructions, I didn't know there was a choice to make there. I just soldered every part to the board, and it appears to have Scott's mods incorporated into the plans.
One of the switches is meant to adjust PWM, I guess it's just built in.
I think I'm just going to try the +-15 thing and see what happens, and see what's involved in calibrating. For now I don't need perfect musical accuracy, but when I figure out a MIDI->CV solution I'll need it. _________________ ==================
mark_olson
Joined: Oct 26, 2006 Posts: 178 Location: Lawrence, Kansas
Posted: Wed Apr 07, 2010 1:43 pm Post subject:
| droffset wrote: | | didn't know there was a choice to make there. |
I don't remember making such a choice either. I just took a loot at Scott's site and didn't see anything about it on the surface. But details often elude me.
| Quote: | | try the +-15 thing and see what happens |
Recall is a little fuzzy but I think I just daisy-chained the necessary voltage from wherever it was nearby.
Mark |
droffset
Posted: Thu Apr 08, 2010 3:25 am Post subject:
| mark_olson wrote: | | droffset wrote: | | didn't know there was a choice to make there. |
You obviously didn't read the instructions properly  _________________ ACHTUNG!
mark_olson
Posted: Thu Apr 08, 2010 7:09 am Post subject:
| v-un-v wrote: | You obviously didn't read the instructions properly  |
Thanks for setting me straight.
I see what you're talking about; in paragraph 2 of Scott's "Anatomy of..."
I improperly read that as an explanation of a circuit design decision but I see that if I had taken a more critical approach I would have seen the invitation to go off-road.
Oh well, not the first time I've been called out for being to "cookbook" in my approach.
I don't have any regrets about taking pwm over extended high end, even though I didn't realize at the time that's the trade-off I made.
One thing I would do differently though is to do the eg response control mod.
Mark |
droffset
Posted: Thu Apr 08, 2010 2:53 pm Post subject:
I'm blind, still can't see it on the website. But it still works without choosing!
This module is sooo much fun to play with. Need to get a new oscilloscope probe to calibrate it properly. _________________ ==================
mark_olson
Posted: Thu Apr 08, 2010 3:00 pm Post subject:
| droffset wrote: | I'm blind, still can't see it on the website. But it still works without choosing!
This module is sooo much fun to play with. Need to get a new oscilloscope probe to calibrate it properly. |
If I'm right about what v-un-v is referring to it is in the second paragraph of this page:
http://mypeoplepc.com/members/scottnoanh/anatomyofthesnvoice/
Yes, it is a ton of fun.
Mark |
droffset
Posted: Thu Apr 08, 2010 3:16 pm Post subject:
Ah ok, cool.
I remember looking at that entry on the parts list and not knowing why it was there.
I'm a cookbook guy I guess. As long as it works it can always be tweaked and modded later.
One thing the instructions could be a tiny bit more clear on is the Env lock switch and if the on-on-on switch is really necessary and how to achieve that function without it.
Other than that very happy. _________________ ==================
mark_olson
Posted: Thu Apr 08, 2010 7:11 pm Post subject:
| v-un-v wrote: |
Yes. And this too (which is a note in the parts list); |
Thanks. I'm embarrassed to admit that unlike droffset, I don't remember ever noticing that even though it most certainly is right there on my parts list too.
I did see the gorilla though
http://viscog.beckman.illinois.edu/grafs/demos/15.html
Mark |
Audio files: 22
Posted: Fri Apr 09, 2010 8:27 am Post subject:
ON the following statement from the anotomy if the SNV:
| Quote: | | Important Note: The SN-Voice uses +/-15V and +5V supplies. To avoid damage to the SN76477, pay special attention to the power connections when building the SN-Voice. |
Just for folks looking from the outisde who have not build an SNV yet. If you use my PC board, an external +5V power supply willl not be necessary. Otherwise, the circuit is virtually identical to Thomas Henry's. The SNV has also been run using +12V/-12V supplies also.
Good discussion though and this made me look back at the underpinnings of how the SN76477 chip behaves.
Bill |
