loss1234
Posted: Wed Jun 04, 2008 5:18 am Post subject:
modulating/mixing waves together? How to? HELP |
Let's say i have five waveform sources. maybe a few are octaves up or down of a square wave. maybe one is a triangle wave. and maybe one is the original square. maybe a few 40106 oscillators as well.
i want to figure out a few ways to take these and have them INTERACT with each other. i dont want to simply mix them. I want to have them effect each other.
The one Idea i had was an R2R ladder. I suppose XMOD is another (for x times y)
but what about FM or AM or any other ways i am not aware of. I basically want to make new and interesting waveforms by having the waves mess with each other.
thanks for the help _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
Joined: Apr 03, 2004 Posts: 18181 Location: Netherlands, Enschede
Audio files: 95
G2 patch files: 310
Posted: Wed Jun 04, 2008 12:09 pm Post subject:
Think "voltage controlled circuits", once a parameter of a module is voltage controlled you can put audio into the control input which may result in interesting things. Basically you can connect anything to everything when the voltage ranges are standardized.
Another interesting feature is oscillator sync, or you could trigger an envelope at audio rates. _________________ Jan |
loss1234
bearblock
Posted: Wed Jun 04, 2008 2:35 pm Post subject:
R2R as in a digital-analogue converter? that is basically a mixer with precisely fixed gain for each channel. in binary the bits represent 1, 2, 4, 8, 16 etc. so the DAC just has to mix all the digital signals together with the correct weights to generate an analogue signal.
| Quote: | | so what about sources that have no voltage control? can they only be used as modulators and not be modulated? |
this is true. you might be able to find nodes on the circuit that do something interesting when you couple them to the output of another circuit, or make very simple mods to allow modulation, like replacing resistors with vactrols. but the whole point of voltage control is that it allows modulation; thats why moog/buchla took the time to invent it  |
loss1234
RF
Joined: Mar 23, 2007 Posts: 1459 Location: Northern Minnesota, USA
Audio files: 29
Peake
Joined: Jun 29, 2007 Posts: 1085 Location: Loss Angeles
Posted: Wed Jun 04, 2008 6:57 pm Post subject:
Check out the circuits Buchla used in the 259 and Easel complex oscillators.
http://rubidium.dyndns.org/~magnus/synths/companies/buchla/
There is FM, AM, and more going on. AM, when voltages are standardized (enough waveform voltage to fully open a VCA) is an often overlooked effect, especially at audio rates.
Also, sequential switches at audio rates switching between other oscillators or used to send modulation to pitch/amplitude etc.; Boolean logic modules for audio, and then out to pitch modulation; patching the filter output back into the oscillator pitch input; adding various filters in modulation paths; etc. |
