Happy New Year!
Thanks for a great live streaming floating concert and party.
How can I save the global octave setting?
Page 1 of 1 [8 Posts]
nosajthing
PostPosted: Mon Jun 30, 2008 12:06 pm    Post subject: How can I save the global octave setting?
Subject description: Midi control
Hello,
I want to use the G2 to control my software instruments. I can change the octave of my software instruments if I open the G2 editor>synth setting>click on Global Octave change. If I power cycle the G2, the setting gets lost. Is there a way to save that setting?
Thanks in advance!
ian-s
Audio files: 39
G2 patch files: 512
PostPosted: Mon Jun 30, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is saved if you store the patch after changing.
nosajthing
PostPosted: Mon Jun 30, 2008 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much...I didn't know that it save it to the patch because it listed global.
G2 patch files: 301
PostPosted: Mon Jun 30, 2008 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
The synth global settings should be saved when "memory protect" is off, that's in the same dialog lower left corner, by default it's on.
nosajthing
PostPosted: Mon Jun 30, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you!
nosajthing
PostPosted: Sun Jul 13, 2008 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys,
I tried both suggestions and they didn't work. As soon as I power cycler the Nord...the Global setting is off. I made sure that the memory protect was off and I also saved it to a few patches. Any other ideas?
Thanks
nosajthing
PostPosted: Sun Jul 13, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found a work around for now. Holding shift then octave will toggle to global octave
G2 patch files: 301
PostPosted: Sun Jul 13, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
This seems to be a bug, all other settings are saved when memory protect is off ... well I didn't try all, but some ... and it's the same here, octave shift gets lost when I power cycle.
Sorry for not trying that myself earlier.
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
