First Use of Tape Delay?
Page 1 of 2 [49 Posts]
rlainhart
PostPosted: Fri Jun 06, 2008 11:07 am    Post subject: First Use of Tape Delay? Reply with quote  Mark this post and the followings unread
For a project I'm working on, I'm trying to find out who first used and recorded with long tape delays as a compositional tool. I'm referring specifically to the technique of running a reel of tape between two reel-to-reel decks to achieve long delay times (not to the standard technique of record-to-playback head echo with a single machine.)
The first composer to use it, and the first recorded piece using that technique that I know of, is Pauline Oliveros' "I of IV" from 1966. Does anyone know of anyone who used it earlier, and especially anyone who released any earlier recordings using long tape delays? Thanks!
Richard Lainhart
http://www.otownmedia.com
http://www.downloadplatform.com/richard_lainhart
http://www.vimeo.com/rlainhart
http://www.airglowmusic.com
Audio files: 20
PostPosted: Fri Jun 06, 2008 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m pretty sure that I´ve heard several US made radio plays from the early 50s that have utilized long delays using magnetized media.
Apart from that, I´m also pretty sure there must be some early works from the BBC Radiophonic Workshop sporting multi-tapped tape loops multi and delays.
OK, and then there is Studio Eksperymentalne in Warzaw, Poland. I think they did have long multi tapped tape echo as early as 1963.
Music at MySpace and Virb - Forum
Audio files: 20
PostPosted: Fri Jun 06, 2008 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I should add that I might have mentioned cases involving custom setups and not simply two plain reel to reel recorders.
cappy2112
PostPosted: Fri Jun 06, 2008 12:33 pm    Post subject: Re: First Use of Tape Delay? Reply with quote  Mark this post and the followings unread
Les Paul did some pioneering with tape, mostly noted for the Sound on Sound technique (which isn't what you're looking for, but..)
This interview
http://www.modernguitars.com/archives/000818.html
refers to phasing & flanging, there may have been some multiple machine experiments, although it's not explicitly stated.
Oddly enough, the interview refers to "it wasn't tape delay, it was disk delay first" (scratching my head)
PostPosted: Fri Jun 06, 2008 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I do remember reading somewhere that it was Sun Ra who discovered tape delay/ echo on his recording "Cosmic Tones for Mental Therapy/Art Forms of Dimensions Tomorrow", recorded in 1961. But this seems somewhat dubious, because like Stein quite rightly pointed out, the Radiophonic workshop's first ever recording used tape echo/ feedback. Wasn't this in the 1950's?
Also there was all those surf bands who used tape delay (or a rotating oil can filed with oil and iron-filings). Also what about Pierre Henry or Pierre Schaffer?
Talking of Pierre Henry....Messe Pour le Temps! The Ballet too!!
rlainhart
PostPosted: Fri Jun 06, 2008 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but I'm not looking for the standard tape-head echo technique, as created with a single three-head tape deck, or any techniques involving tape loops, Echoplexes, slapback, sound-on-sound, SelSync, or what have you.
I'm looking specifically for the first use and first recording of music based on long delays (greater than 5 seconds), created by running tape between two reel-to-reel decks located some distance apart, with the supply reel on the first deck and the take-up reel on the second. You then record audio into the first deck, play it back on the second, and feed that playback into the first machine to create the long repeating delays in realtime.
For those unfamiliar with this, this is also known as the "Frippertronics" system, but developed years before Fripp's first use of it.
Richard Lainhart
Audio files: 20
PostPosted: Fri Jun 06, 2008 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Long multi-tap echo on tape would involve either two decks as rlainhart describes.. or custom jobs involving several sets of heads, a seriously lenghtened and adjustable tape travel and head feed mixers. The one setup used at NRK in Oslo in the early 60s used aux outs and ins for using other reel to reel decks for adding pre delays or more echo between the taps.
Audio files: 20
PostPosted: Fri Jun 06, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyways, this would be fairly easy to sort out. AFAIK, it would be absolutely dooable to make a list of the most important "academic" sound studios with tape equipment ( and set up for entertaining clever academic composers ) .
There is at least one and a half generation of people still alive who would be possible to reach by a simple phone call.
Actually, the one guy to call first would be the norwegian composer Arne Nordheim. He did some really stunning work involving tape echo and he has been around as well. He would know who to call next.
cbm
PostPosted: Fri Jun 06, 2008 1:27 pm    Post subject: Re: First Use of Tape Delay? Reply with quote  Mark this post and the followings unread
I also think that the technique, as you describe it, came out of the San Francisco Tape Music Center. I've heard Pauline and Terry Riley accuse each other of being the first to use it. It's clear that Pauline released something before Terry, although Terry was playing with it significantly before "A Rainbow in Curved Air" was released.
-C
Chris Muir
PostPosted: Fri Jun 06, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just going to say Terry Riley Smile
Audio files: 28
G2 patch files: 299
PostPosted: Fri Jun 06, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Besides the wikipedia article on frippertronics there is also this one on tape loops, but it's not clear where the article refers to pre-recorded or live-recorded loops, neither is it clear if two machines are involved. It's funny that the two articles have no links to each other.
http://arts.ucsc.edu/ems/music/equipment/analog_recorders/Analog_Recorders.html#Loops makes a clear distinction between loops and echoes ...
Then we have this article about delay mentioning Karl Heinz Stockhausen and Pierre Schaeffer to use up to "several" tape recorders for delays ... but not when ... and not specifically two ...
The we have :
The two-machine tape delay and feedback system (which later evolved into Frippertronics and digital loop delays) was apparently invented by an anonymous engineer who worked for Terry Riley during the Paris sessions for Riley's Music for The Gift.
from loopers delight. Also see http://www.terryriley.com/magnet_article.htm
Audio files: 20
PostPosted: Fri Jun 06, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree that this is utter stupidity. The Sun Ra mythology is sometimes too embarassing for words.
My bet is that the first use of a tape delay chain conforming to Richard´s requirements would either be in radio or film sound design in the US ( because this is where the bulk of such happened anyways.. think scifi radio plays in the early 50s ) or it would be in Europe. My bet is also that it didn´t involve tape but wire and most likely in the late 40s. Uh.. but one requirement seems to be that this delay chain resulted in serious music I dunno if radio qualifies.
The Siemens lab is also a likely suspect.. but it´s still a bit late.
Audio files: 28
G2 patch files: 299
PostPosted: Fri Jun 06, 2008 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The loopers delight link I gave above also states :
Music for The Gift (1963), written for a play by Ken Dewey, was the first piece ever based on a tape delay/feedback system with 2 Revox tape recorders - a setup Riley used to call the "Time Lag Accumulator". The source material for Riley's loops consisted of recordings he made of the Chet Baker quartet playing Miles Davis's So What. It was this looping piece which got Riley really interested in repetition as a musical form, leading the way to his breakthrough as a minimalist composer and performer.
rlainhart
PostPosted: Fri Jun 06, 2008 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell, thanks for that article - "time-lag accumulator" sounds like a good term for that system.
The tape-loop article was unclear. When I think of tape loops, I mean actual physical, spliced-together loops of tape with pre-recorded content, strung onto a tape deck and played back without further recorded input, Steve Reich's "Come Out" being the prime example of that.
Live looping, to my mind, requires some sort of feedback of the live recorded content back into the system, "A Rainbow In Curved Air" being an excellent example of that. That's the kind of system I'm referring to in my original question.
Richard Lainhart
Audio files: 20
PostPosted: Fri Jun 06, 2008 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan, I know that one.. but..
Considering that Studer Revox gear, often prototypes, were shipped directly to academic institutions in Europe, and Ferrograph often did the same.. and that basically the european avant garde and academic experimental music lay light years ahead of the US .. this would probably yet again be a myth. Sad
rlainhart
PostPosted: Fri Jun 06, 2008 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I didn't see your second reply before I sent off the previous one. If the Looper's Delight article is correct, that might be the first usage of such a system, although it doesn't sound like it used live input, nor was used in live performance.
Richard Lainhart
Audio files: 28
G2 patch files: 299
PostPosted: Fri Jun 06, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing search for evidence Exclamation
Seriously, I'm amazed but I can't find anything concrete in EU history about two recorder live looping setups.
Audio files: 28
G2 patch files: 299
PostPosted: Fri Jun 06, 2008 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
It all seems to back into the fog of history ... http://www.jerryfielden.com/essays/PIONEERS.HTM might be of interest for it's references?
Audio files: 20
PostPosted: Fri Jun 06, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the obvious thing would be to call the guys still alive.
And I am fairly certain that using two decks wouldn´t be seen as a big issue at all. Engineering and electronic music in Europe at that time was basically about looking at the gear and then use it to the full potential. If you can do it with the gear right out of the box then there wouldn´t be any innovation going on at all. It would simply be about using the gear as it was intended to be used. This mindset is inherent in just about anything produced by the BBC Radiophonic Workshop during its early years.
Audio files: 20
PostPosted: Fri Jun 06, 2008 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, that´s how academic music and the story of instrument design goes over here. It´s very badly documented on the web and noone really cares.
How many of you guys had really heard about the Subharchord before I posted this one: http://electro-music.com/forum/topic-11091.html
BTW.. It seems that it is not completely unlikely that I just might be able to get access to one.. and write music for it. Uh.. the Subharchord that is...
cbm
PostPosted: Fri Jun 06, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahem...
Charles Ives
George Antheil
Conlon Nancarrow (although we might have to cede him to Mexico)
Henry Cowell
Morton Feldman
Elliot Carter
John Cage
Harry Partch
Max Mathews
Milton Babbitt
Vladimir Ussachevsky
Charles Dodge
Aaron Copland
Pauline Oliveros
Morton Subotnick
Terry Riley
Steve Reich
Lou Harrison
Louis & Bebe Barron
Bernard Herrmann
Miles Davis
Buchla, Moog, Oberheim, Rossum, Smith
and many others.
In addition to the usual European suspects (Stravinsky, Schoenberg, Berg, Webern, Boulez, and many others), I'll even grant you Stockhausen, but given his extra-terrestrial origins, I'm not sure Europe can really claim him. Smile
All told, I'm not sure I would classify the European scene particularly "ahead" (whatever that means in this context) and certainly not "light-years" ahead. A light year is quite a large distance.
Shouldn't music be removing jingoistic attitudes, not trying to enforce them? I very much like Terje Rypdal, and Jaga Jazzist, and even Edvard Grieg, fine Norwegians all.
-C
Chris Muir
Audio files: 20
PostPosted: Fri Jun 06, 2008 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Excellent!
I knew I would tickle some vital parts.
Basically the list of legends in Europe doesn´t exist like it does in the US. The academic style didn´t allow that to happen. Instead the dudes and gals did what they did instead of making a fuzz out of it.
cbm
PostPosted: Fri Jun 06, 2008 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
D'Oh! Trolled by an admin!
The "dudes and gals" here also just did what they did, they also just happened to be able to get it documented at the same time. As someone who grew up in the San Francisco area, it just seemed normal, to me. Morton Subotnick or Steve Reich in concert at the Berkeley museum? Sure. Strange music on radio KPFA, of course. Another Terry Riley gig? Why not?
I think that over half the people on my list are/were also academics. One of the reasons the US may be over-represented on any list of 20th Century Musical Lions is that, mysteriously, during that period there were a couple of American labels with an interest in putting out records of challenging stuff. Nonsuch, Columbia and a couple others were happily issuing "difficult music". Go figure.
-C
Chris Muir
Audio files: 20
PostPosted: Fri Jun 06, 2008 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that ´s an excellent point. They actually did manage to get stuff out on vinyl. It just happened for some reason, and that changed everything.
When I think back, I tend to remember that it was more common to hear US avant garde on the radio here in Norway in the 60s than european material. The recordings did of course exist but not on vinyl.
Try this: http://www.boomkat.com/item.cfm?id=12771
The modern music history in Europe is bit more complex than what is commonly known. There are many alternative Schoenbergs and several different paths to enlightenment. Laughing
The utterly brilliant and original composer Fartein Valen is one starting point. You may want to google the guy.
A point to make is that modernism in music probably kept at it for way longer over here than in the US and that what for you guys in the US became known as East Europe was for us over here something completely different. Within the field of academic modern classcial music, this section of Europe was still a part of Europe. I mentioned the Subharchord in post way back in this thread. That one came out of the Communist Block. Laughing
It was in fact both possible and seen as a smart move for a mad norwegian composer to study electronic music in Warzaw in the mid 50s. ( Arne Nordheim )
Audio files: 28
G2 patch files: 299
PostPosted: Fri Jun 06, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
YThere are many alternative Schoenbergs and several different paths to enlightenment. :lol:
Yup, and every country had their own, most not even known at home ... oom .. it is only for the last ten years or so that early Dutch electronic music is being released at some scale, I (almost) never heard that stuff on the radio BTW.
