Triangle out of cd40106
Page 1 of 1 [14 Posts]
kaputtpanzer
PostPosted: Tue Jan 19, 2010 3:13 pm    Post subject: Triangle out of cd40106 Reply with quote  Mark this post and the followings unread
Hey i tried to get a trianglewave out of the cd40106, i built it like this on my breadboard: http://www.elecfree.com/electronic/wp-content/uploads/2009/09/triangle-and-squarewave-generator-by-ic-40106.jpg
The output signal is very low, I tried to amplifie it with a tl072. Now it`s loud enough, but this is a very complicated way. And the signal is not so clean, it is something between a triangle and a squarewave!
What is the easiest way to get a strong and clean triangle out of a 40106???
frijitz
Audio files: 54
PostPosted: Tue Jan 19, 2010 5:36 pm    Post subject: Re: Triangle out of cd40106 Reply with quote  Mark this post and the followings unread
Error 404 - Not Found
Sorry highly. Page you want to see. Changes.
Please find the new.
kaputtpanzer
PostPosted: Tue Jan 19, 2010 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh sorry now the link works!
synthmonger
PostPosted: Wed Jan 20, 2010 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
This works great:
http://www.cgs.synth.net/modules/cgs21_super_psycho.html
Youtube!
modular demos!
Whacky tunes!
kaputtpanzer
PostPosted: Wed Jan 20, 2010 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh ok thank you. But I don`t want to use bipolar power supply.
synthmonger
PostPosted: Wed Jan 20, 2010 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use a virtual ground then. Wiki or google it for all the info you need on it if you don't know what it is.
Youtube!
modular demos!
Whacky tunes!
ezekiel
PostPosted: Fri Jan 22, 2010 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or use an LM324 for single-sided supply.
The triangle wave pulled from the CMOS inverter oscillator is going to be coming out both weak and out-of-shape. The op amp is needed as a buffer and possibly an amplifier before feeding that triangle into the subsequent circuit.
I guess what you are saying is that if you need an op amp, you may as well not use the 40106 and just use a dual or quad op amp for an official, sharp triangle oscillator.
synthmonger
PostPosted: Fri Jan 22, 2010 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Buffer and amplifier help correct it's symmetry and amplitude. Granted, it's not a perfect triangle but it's pretty close. Of course it would be easier to just look up a dual op-amp LFO schematic. Less parts too.
Youtube!
modular demos!
Whacky tunes!
kaputtpanzer
PostPosted: Thu Jan 28, 2010 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm ok.
maybe this will work without bipolar power supply???
http://www.elecfree.com/electronic/wp-content/uploads/2007/07/ckt17_1.gif
ezekiel
PostPosted: Sat Jan 30, 2010 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I just tried it with LM324 and 9V/0V supply and got an oscillation but too low level to confirm its waveshape on my lowtech mixer/PC.
Then, I attached the two ground points to 4.5V. Output was stronger, but still quite low level, but now clearly ramp/sawtooth.
I put a 300k pot in place of the 120k resistor and got a roughly 50 Hz to 200 Hz range. I think this circuit needs some beefing up for usefulness in synths.
hexagon5un
PostPosted: Wed Feb 03, 2010 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
The triangle wave out of a 40106 or similar oscillator ends up bouncing back and forth between 1/3 VCC and 2/3 VCC, so yeah the signal needs about 3x gain to swing full-range. If you're going into a dual-supply op-amp that shares ground with your 40106, you'll want to pass it through a capacitor to pull off the 1/2 VCC offset.
One quick-and-dirty trick is to use an unbuffered inverter (4069UB for 9v, 74hc04U for 5v -- the "U" is crucial) as an amplifier -- it ends up giving just about the right amplification with a little clipping distortion that I kinda like. It ends up like a sine-waveshaped triangle. You still end up with a positive (single-supply) signal, but it's rail to rail.
Try that out if you've got the parts around.
kaputtpanzer
PostPosted: Fri Feb 05, 2010 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks i think i order some 4069s and try it. if i get a good result i think i will draw a basic schematic, just for newbies like me.
kaputtpanzer
PostPosted: Tue Feb 16, 2010 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.talkingelectronics.com.au/ChipDataEbook-1d/html/images/4069-fig2a.gif
Is this a good way to amplify the signal?
kaputtpanzer
PostPosted: Mon Mar 01, 2010 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tried it, but i don't get a good result. when I amplifie the signal with the 4069ube the output is a squarewave. do you have a schematic?
