How Do I Control a Switch with Clock On/Off?
Page 1 of 1 [2 Posts]
buzz
PostPosted: Mon Dec 27, 2004 11:10 am    Post subject: How Do I Control a Switch with Clock On/Off? Reply with quote  Mark this post and the followings unread
I'm sequencing an external piece of gear with the G2 (an Elektron Sid Station) and running it thru the audio ins.
If I stop the clock while the sequence is on a note, the Sid continues to play.
I know the easiest solution would be sending a note off but I'm so clueless I can't even figure out how to do that.
My next attempt was a noise gate, but it does no good if the Sid keeps playing.
Now I'm just trying some kind of switch that allows the audio to pass thru if the clock is on and cuts the signal when the clock is off. I've attempted to put a switch between the signal but I can't figure out how to make it flip on or off. How can I send a value from the midi clock?
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Mon Dec 27, 2004 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The Clk Active output might be what you want.
