DUSG vs VCS
Page 1 of 1 [4 Posts]
roman_f
PostPosted: Sat Oct 29, 2011 9:32 am    Post subject: DUSG vs VCS Reply with quote  Mark this post and the followings unread
is there any difference?
or 1st module is just 2 VCSs?
Dave Kendall
PostPosted: Sat Oct 29, 2011 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
As far as I can tell , looking at the schematic, the VCS is a single channel version of the DUSG, but has several added features not found on the DUSG.
* A dedicated cycle switch that is independent of the TRIG in. You can cycle with the DUSG, but need to patch OUT to TRIG in.
* CV inputs for FALL and RISE in addition to the switchable FALL/BOTH/RISE CV input.
* Switches for FALL and RISE to make the responses exponential.
* An additional AC output. (which presumably centres the output around 0V)
* An independent patchable CV processor section.
"The Higgs Bosun's finally been found. So where's the Higgs Captain?"
sonicwarrior
PostPosted: Mon Jun 18, 2012 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The VCS PCB has a MOTM power connector on board which in my eyes is a biiiiiig plus.
otherunicorn
PostPosted: Tue Jun 19, 2012 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The primary difference is that the VCS had independent VC control of rise and fall times at all times, while the DUSG lets you control rise OR fall OR both together.
http://www.cgs.synth.net/
AmbiphonicDSP
