 Forum index » News... » Gear News
White Noise Additive Synth
Page 1 of 1 [2 Posts]
PostPosted: Mon Jan 12, 2004 11:30 pm    Post subject: White Noise Additive Synth Reply with quote  Mark this post and the followings unread
White Noise Audio Software Releases Additive Synth
Version 1.0 of White Noise Additive Synth has been officially released as a VSTi plug-in for Windows.
The sound engine allows for massive possibilities with its timbre-morphing oscillators and filters. It excels at evolving ambient pads, basses, leads, vocal sounds, and wierd sounds impossible to get in other synths.
2 Spectral Oscillators
128 partials each oscillator
each oscillator has 128 "time frames" to allow sounds to evolve and change over time.
FM capabilities
Ringmod, compression, reverb, distortion, stereo chorus/delay and phaser
Load .BMP Files as spectrums
2 Envelopes which can modify any parameter
2 LFO's with multiple wave shapes, including arp patterns
Unison effects to phatten up any sound
128 Band formant filter or noise spectrum
Can act as a 128 band vocoder
formant filter has 128 time frames to allow changes over time
Formant Bias parameter also allows formant filter sweeps similar to sweeping the cutoff on an analog synth.
Flexible mod section
On screen XYPad allows you to modulate parameters easily
packaged with 128 presets plus dozens of waveforms and filters to make your own sounds with or create your own
Visually draw your own waveforms and spectral changes, similar to products like Metasynth (tm) and Coagula(tm)
draw your own filters
Captures the unique and sought after sound of the great Kawai K5000 (tm)
A programmers heaven, this synth will let you create nearly any time of synthesized /sound.
http://www.whitenoiseaudio.com/
Flickr
seraph
Editor
Editor
Audio files: 31
PostPosted: Tue Jan 13, 2004 6:41 am    Post subject: Re: White Noise Additive Synth Reply with quote  Mark this post and the followings unread
if it were true it would be nice.
that synth was really something but......windows only Sad
Niio1
