Jack wiring question
Page 1 of 1 [2 Posts]
schizophonic
PostPosted: Sun Dec 03, 2006 4:30 pm    Post subject:  Jack wiring question Reply with quote  Mark this post and the followings unread
It says to wire one side of the jacks to point 'AA' and another to point 'C' on the front panel. I can't for the life of me figure out where these are. Where do you wire the output jacks? Thanks!
fluxmonkey
PostPosted: Sun Dec 03, 2006 9:29 pm    Post subject: Re: Jack wiring question Reply with quote  Mark this post and the followings unread
AA is the center lug of R27, the volume control pot. C is a ground conneciton; on the diagram Ray shows this on R44 (the noise level), but you could just as easily connect it to the ccw lug of R27 so as to keep the 2 together... or any other ground connection, whatever's easiest.
also don't forget r23 & c22 in your output path...
b
