 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
Feature Request: G2-a-like functions
Page 1 of 1 [15 Posts]
erstlaub
PostPosted: Fri Mar 23, 2007 6:08 am    Post subject: Feature Request: G2-a-like functions Reply with quote  Mark this post and the followings unread
Greetings.
I recently dragged my NM out of retirement and have come across a few "issues" with v3.03 that I was wondering if there was the possibility that they may be addressed in some future update.
The main thing I'm really finding a pain is the lack of being able to set the colour of modules. I know there has been some talk about custom skins and the like but I personally would be far happier having a "boring" interface with that ability.
Would a midi learn style function ever be possible? The ability on the G2 to select a parameter, waggle a knob and hit the L key to assign it really helps speed up workflow.
Oh and the moon on a stick while you are at it please.
Keep up the awesome work, looking forward to the next update.
Cheers.
D
edit: i was talking rubbish about a potential problem I was having. Deleted
chresan
PostPosted: Fri Mar 23, 2007 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Erstlaub,
first the learning function for the parameters/knobs as far as I know is not possible because the synth does not send the necessary messages to the editor when an unassigned knob is turned. I will take a close look to ensure my assumption is correct.
For custom module colors the main problem is that I cannot change the patch format (file/synth) and even if it were possible these patches would not be compatible with clavias editor. However, I see two ways it can be realized. 1. The color settings could be stored in the notes section. 2. An algorithm could apply the module colors automatically by deducing what a module is used for (requires not to store the settings).
I understand that custom module colors is a very useful feature so chances are good this feature will make it into the next release.
Christian
http://nmedit.sf.net
julien
PostPosted: Mon Mar 26, 2007 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Christian,
Couldn't we create a save file format for nomad that would include the patch file + the additional needed information, such as modules' color. The save command would create such a bundle and we could add an "export to patch file" entry to save only the patch file that is compatible with the legacy NM editor. The "export" verb would also remind the user that the bundles contain more than the patch file and are not directly compatible with the legacy editor.
Julien
chresan
PostPosted: Mon Mar 26, 2007 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Julien,
to give you a precise reply I have to expose some goals of the nomad project. Basically the idea is to develop an infrastructure to implement editor views for arbitrary synthesizers which then can be embedded in Nomad. I have already developed and implemented a basic Patch API. As complement my plan is also to provide a generic patch file format.
Once this patch file format becomes real we could add such features like custom module colors.
It is clear that for nm1 patch files this makes the compatibility problem even worse. But there is a simple solution, instead of saving only the new patch file format we use a jar file as container and put both the new and the old file in there. So if someone has only clavias editor at hand he can unzip the compatible patch file and use it instantly.
The container format has further advantages. For example we can store variations of a patch or optionally thumbnails to provide a preview of the patch.
Now what do you say ? Very Happy
Christian
julien
PostPosted: Mon Mar 26, 2007 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's exactly what I thought about.
Julien
PS: Christian, based on your answer I guess it was not clear that I am the "Julien" of the graphics modules.
chresan
PostPosted: Mon Mar 26, 2007 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
julien wrote:
... PS: Christian, based on your answer I guess it was not clear that I am the "Julien" of the graphics modules.
Well, because of your user name and location: Brussels I was 90% sure it is you. I try to be detailed in my postings so people who are interested have some insight to the development process.
By the way, I am happy you are also member of this board now Smile
Christian
hyperstationjr
G2 patch files: 24
PostPosted: Fri Apr 13, 2007 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I figured this would be as good a location to post as any...
Anything in terms of additional modules or capabilities? Is that sort of thing just way more work than you guys are able to do?
Studio:
Blokas MidiHub, Clavia Nord Modular G2 Engine, Elektron Analog Four Mk2, Elektron Digitone, Elektron Machinedrum UW+ Mk2, Elektron Octatrack Mk2
For Sale/Trade:
Alesis Microverb 4, Make Noise 0-Coast, Monome Norns Fates clone, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Yamaha TG55
Audio files: 278
PostPosted: Fri Apr 13, 2007 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too hard indeed Very Happy
For the time being at least. It would require the software in the synth itself to be modified. Some people have raised the subject though of reverse engineering the synth itself, so you never know.
chresan
PostPosted: Tue Jul 17, 2007 10:33 am    Post subject: Re: Feature Request: G2-a-like functions Reply with quote  Mark this post and the followings unread
Hi Erstlaub, I just implemented this feature in the Nomad editor. In the next release it will be possible to modify the module colors. The configuration is stored in the patch and is not lost - even if the patch was modified by clavias editor or stored in the synth.
The next release will be available in a few weeks (sorry I can't be more precise).
Christian Smile
license
PostPosted: Sat Aug 11, 2007 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chresan I guess it sounds like you are already working on it, but I have an idea.
Instead of storing module colors in the notes section, how about a magic character that could be put into the name of the module to determine its color, e.g. # in "Main Osc #F4B" or "Sub Osc #Blue". I'm not sure which characters are legal for names in the editor as I haven't played with it, but there's probably at least one. Invalid input could be ignored, and also colors could be changed very quickly just by renaming a module. You could also hide the color from the name of the module until the module is renamed to make it look a little more attractive.
Just a thought. Smile
Audio files: 278
PostPosted: Sat Aug 11, 2007 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome license.
The problem of your proposal I think is that module names are limited to 16 characters.
license
PostPosted: Sun Aug 12, 2007 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
BlueHell, thank you! Very Happy
That is restrictive. But colors could be defined in as little as 2 characters - maybe a pound or similar special character like I mentioned and then a letter to determine just the hue.
This would probably be better than an RGB value not only because it takes up just one character but because it would be difficult to ensure readability with lots of variations in saturation and brightness.
If someone wanted to use all 16 characters they could do so and simply ignore the 2-character color markup and assign a default value.
chresan
PostPosted: Sun Aug 12, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
The color values are encoded in the module names, not in the notes section like I said in my earlier posting.
Rather than specifying a color value a string is used as key which is seperated from the module name using the '$' character:
Code:
{module name} '$' {key}
The key can be associated with any color according to the users preferences (key1=red,key2=green,...).
I am currently using only the digits 1-9 as keys (like in Osc$1, Osc$2, ...). So there are only 2 additional characters necessary per module (except for the default color).
Christian
license
PostPosted: Sun Aug 12, 2007 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, I'm looking forward to it Smile
chresan
PostPosted: Sun Aug 12, 2007 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Me too Smile . Actually I planned to release in February / March, but we did a massive rewrite of nomad which caused the delay. For the next release we mostly have to fix some bugs, what I hope it will not take too much time. There will be a lot of surprises for our users in the upcoming releases Very Happy
Christian
