getting hot
Page 1 of 1 [6 Posts]
TOTAL
PostPosted: Sat Mar 24, 2007 8:49 pm    Post subject: getting hot Reply with quote  Mark this post and the followings unread
I have bought a used Nord Rack 3. It will unfortunately go back to the previous owner because the rotary dial was broken in transport, but hopefully the gets back to me for good.
I have noticed Nord Rack 3 gets very hot at the radiators after some time. Is it normal for this synth?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Apr 01, 2007 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
'Very hot' is not normal. Are you burning your fingers?
It's normal when it gets 'warm'.
Wout
TOTAL
PostPosted: Sun Apr 01, 2007 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncomfortably warm when touching longer time.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Apr 01, 2007 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
The power suply of the Leads is known to get hotter then others. As long as the synth is working fine. You must be able to hold it.
Wout
TOTAL
PostPosted: Sun Apr 01, 2007 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK. TY
kvnvk
PostPosted: Tue Apr 03, 2007 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
just got a Nord Rack 3 as well and noticed the same thing, after about thirty minutes the back and underside around the middle of the module gets very warm, bordering on what I'd call hot. doesn't really seem normal to me either, as it gets much warmer than any other piece of gear I own. I had it running for a good hour and a half yesterday with no problems, but it does make me a bit nervous about the longevity of the unit. Confused
