WSG volume question
Page 1 of 1 [7 Posts]
abis
PostPosted: Sat Apr 28, 2007 8:35 am    Post subject: WSG volume question Reply with quote  Mark this post and the followings unread
I have a Weird Sound Generator on the bread board and, before I solder it to a board, I'd like to know if anyone has found that the unfiltered volume is extremely loud. Or have I missed a connection somewhere. Any advice? Thanks.
crazeydazey
PostPosted: Mon Apr 30, 2007 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yep I also found this and posted my question here but never really got the answer I was looking for..
good luck..
abis
PostPosted: Mon Apr 30, 2007 5:42 pm    Post subject: WSG volume question Reply with quote  Mark this post and the followings unread
Thanks Crazeydazey.
Your cardboard mock up looks way cool. What program did you use to design the printout? I am looking for something that I can use on my Mac.
I tried adding a 10k pot to my WSG, and now have some control over the volume for the unfiltered output, but 90% of the pot's range is in the danger zone. I am wondering if I should look for a 10k trim pot to hide inside the case. Any thoughts?
crazeydazey
PostPosted: Tue May 01, 2007 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers Very Happy , I used photoshop, it doesn't look as good close up though so I've redesigned it, also I've built it on stripboard now (it's still a lot louder before the filter), so when it's finished and boxed I will take another picture and some samples and post them..
it's not a bad idea, you can find the volume your happy with and leave it there with a trim I suppose.
I just turn the gain down on the mixer..
Wild Zebra
PostPosted: Tue May 01, 2007 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
try using a linear pot if you haven't. How do you have it hooked up?
like this http://musicfromouterspace.com/analogsynth/oddsandends.html#POTDIVIDER
experiment with pot vaules
"your stripes are killer bro"
PostPosted: Wed May 02, 2007 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
If most of the pots travel is too loud, you probably need a log pot. They have an "A" printed on them if they don't actually say "Log".
Wild Zebra
PostPosted: Wed May 02, 2007 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Word UK, I read it wrong thinking he meant it was all bunched up at the end. Embarassed
