a trigger IN midi OUT gear ?
Page 1 of 1 [11 Posts]
kragg
PostPosted: Tue May 08, 2007 2:40 pm    Post subject: a trigger IN midi OUT gear ?
Subject description: looking for some gear with midi out and trig IN
Hi
I am looking for some hardware gear which would be equipped with midi out port and a trigger IN port.
I have several midi gear, and also some drum machines with trig out, but nothing with trig in to make it all play together.
Would you have any advice of such a thing ?
THanks !
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue May 08, 2007 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi kragg
welcome to electro-music.com Very Happy
check this out:
arrow http://www.roland.com/products/en/TMC-6/index.html
kragg
PostPosted: Tue May 08, 2007 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Thank you for your quick answer !
The purpose is mainly syncing (more than triggering), i would like to send a constant trig note that could be understood as a midi tempo signal by my daw.
Would you know if there is there any specific module dedicated to this task ?
Or could i go for the cheapest one to do that job ?
thanx
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue May 08, 2007 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
check this out
arrow http://www.borg.com/~jglatt/tech/midispec.htm
and read what they say about "midi clock"
maybe that's what you are looking for
kragg
PostPosted: Wed May 09, 2007 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
seraph wrote:
check this out
I don't get it : I think i have understood what i've read, but what's the relation with the thread ?
I mean : my drum machine is PRE-midi, so it doesn't send any miodi clock message, it can only send trig OUT, so, to use it as a master tempo, i have to find a way to convert trig out to midi clock. As some daw/plugin can convert midi messages to tempo messages, i need to convert trig OUT to any message.
Does this make sense ?
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed May 09, 2007 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
it does, I had not understood your drum machine was pre-midi.
kragg
PostPosted: Wed May 09, 2007 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok ! Very Happy
BoomBoxJohnny
PostPosted: Sun May 27, 2007 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi! I have a similar question
i own a Korg Rhythm 55 drum machine, a Roland MC202 sequencer and a Korg KMS-30 Midi synchronizer and would like to sync the drum machine with the sequencer. is it possible?
here is some pics i have of the back views of said equipment
any help would be very much appreciated!
thanks!
kragg
PostPosted: Sun May 27, 2007 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
AS your drum machine only have trigger out, i think it is the only gear able to act as "master" clock, and you have to get the mc-202 be the slave and receive a constant trigger from the korg55.
Beware with the 24/48ppqn conversion.
BoomBoxJohnny
PostPosted: Sun May 27, 2007 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, you're right. what i don't know is how to connect them. the korg rhythm55 has a JACK-type output and the roland mc202 has a DIN-type input
that's what confuses me
Sad
kragg
PostPosted: Sun May 27, 2007 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
din is din
midi is midi
and jack is fro triggering, you can use any audio cable
you can't connect trig to din or din to midi or whatever else.
