moosapotamus
Joined: May 11, 2007 Posts: 113 Location: New Hampshire USA
Posted: Mon Jul 09, 2007 7:42 pm Post subject:
Anyone add a ring mod to their Soundlab Mini? |
Where did you (or, would you) wire it in?
I'm thinking of a couple of rotary switches to select the X and Y inputs from either osc1, osc2, noise, external input, ... But then where to send the output? Would you tap into one of the mixer channels, or bypass the mixer and go right to the filter? Any other ideas? How would others consider doing it?
Thanks
~ Charlie _________________ moosapotamus.net
"I tend to like anything that I think sounds good" |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Posted: Tue Jul 10, 2007 6:27 am Post subject:
Re: Anyone add a ring mod to their Soundlab Mini? |
moosapotamus wrote: | Where did you (or, would you) wire it in?
Thanks
~ Charlie |
I've created a ring mod of the unused OTA on the board and I sent it to the mixer before hte filter. Just like an external input, but internal
The X and Y is tapped from the oscillator volume pots and I used a DPDT switch to send them either directly to the filter (ring mod bypassed) or via the ring mod. _________________ YouTube channel
flickr photostream
http://loxodrom.blogspot.com
http://soundcloud.com/loxodrom |
Wild Zebra
Posted: Tue Jul 10, 2007 7:28 am Post subject:
My poor Sound Lab has a spot ready for a RM, but I patched mine. (so not much help) One of these days I'm going to build or buy Ken Stone's passive RM. I see you been visiting lately moose. That tau pipe summoned you .
Haven't been to Aron's in a while the synth world sucked me in. _________________ "your stripes are killer bro" |
moosapotamus
Posted: Tue Jul 10, 2007 7:46 am Post subject:
Hey WZ... yeah, still just getting my feet wet. But, I'm getting sucked in, too. Can't wait for the tau pipe! And the Klee! And...
I already have a couple of little passive RM boards that I grabbed on ebay a while ago. So, I was thinking of including one in my soundlab.
Pehr... thanks for the reply...
So, did you add another pot and resistor to make a fourth input for the mixer (for the ring mod output)?
Quote: | The X and Y is tapped from the oscillator volume pots and I used a DPDT switch to send them either directly to the filter (ring mod bypassed) or via the ring mod. |
Not sure I understand... when the ring mod is bypassed, you also bypass the mixer and send the VCOs directly to the filter?
I'm also planning to add the guitar trigger and am thinking it would be cool to be able to route that external input to one of the ring mod inputs... maybe just have a switch to select either VCO1 or the ext input for one of the RM inputs.
Am I also correct in thinking that, if you tap the oscillators for the ring mod inputs, you can leave them connected to the mixer and be able to blend in the regular VCO sounds with the ring mod sound?
Wild Zebra
Posted: Tue Jul 10, 2007 9:13 am Post subject:
Quote: | I already have a couple of little passive RM boards that I grabbed on ebay a while ago. | Hmmm I'll have to keep an out out there. I really would like to have one.
I can attest to the guitar trigger it works well. I haven't used it in a while. The enclosure I chose doesn't make it handy and last time I opened it up it had a blown battery so I need to check it out. Anyway it was real sweet tons of interesting tremolo variations and filtering possibilities. _________________ "your stripes are killer bro" |
