  DarthBuddha Meat Pinata http://meatpinata.com
  Shane Morris Atmosphera #32 - "Friday the 13th"
will 566 cans work for th designs??
Page 1 of 1 [8 Posts]
loss1234
PostPosted: Tue Nov 13, 2007 10:20 am    Post subject: will 566 cans work for th designs?? Reply with quote  Mark this post and the followings unread
well the only 566's i can find are online at ebay and they are the metal can versions. now i know there has been talk of a 566 pcb. will these work with this? or will they fit properly in any other TH designs?
thanks
goodrevdoc
PostPosted: Tue Nov 13, 2007 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes they will do fine. The metal tab is pin 8 and viewed from above, the pins count down clockwise, just like a regular DIP-8.
-justin
Audio files: 22
PostPosted: Thu Dec 20, 2007 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
For now on, it might be a good idea for anyone designing a board that utilizes the 566 VCO to put the PCB "footprint" for both the Metal CAN and DIP packages. I will most likely do a Rev "B" board for the UD-1 that will add this. I know you can bend the leads around to make it fit but I am a stickler for neatness.
I know this VCO chip is really good and has some fantastic literature written about it but probably would not encourage anyone to use it in a new design if they plan to market it since the supply of these beautys are diminishing. Too bad for that Very Happy For DIY, sure go ahead if you have a few on hand. The XR2206 could be the closest replacement. For basic VCO duties, the CD4046 will do. Both of these are in plentiful supply Very Happy
Bill
Tim Servo
PostPosted: Thu Dec 20, 2007 12:44 pm    Post subject: will 566 cans work for th designs?? Reply with quote  Mark this post and the followings unread
Dave Brown did a VERY nice job with a 566 can...
http://www.modularsynthesis.com/magicsmoke/566/566.htm
I don't really have room to include both footprints on the 566 VCO board, but it looks like a little careful bending and forming does the trick.
I would agree that the 566 really shouldn't be used in a "new" design, but the UD-1 is a good use for a 566 if you have one. Of course, I think the 566 VCO is another good use, but I'm biased Wink
Tim (bending and forming) Servo
Danno Gee Ray
PostPosted: Thu Dec 20, 2007 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim,
Any idea when the next run of 566 VCO boards will be in?
Tim Servo
PostPosted: Thu Dec 20, 2007 7:03 pm    Post subject: will 566 cans work for th designs?? Reply with quote  Mark this post and the followings unread
Danno Gee Ray wrote:
Tim,
My guess is with the holidays, we will probably see them early in January. Hopefully sooner, but I wouldn't hold my breath.
Tim (turning blue) Servo
Danno Gee Ray
PostPosted: Thu Dec 20, 2007 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks.
davebr
PostPosted: Thu Dec 20, 2007 9:02 pm    Post subject: Re: will 566 cans work for the designs??
Subject description: 566 cans
You just bend the leads a bit to fit the hole pattern, then just press it down. The leads conform quite nicely.
The frequency coefficient on the LM566 is different from the NE566 but everything adjusted just fine.
