Gothboy
Joined: Feb 21, 2006 Posts: 369 Location: Santa Monica, Ca.
Posted: Fri Dec 14, 2007 7:50 pm Post subject:
Recording Micro knob movements Subject description: Recording Micro knob movements |
It's been a while since I've used the micromodular....(all those softsynths! ) and now I'm getting back into it again this time using it and the editor in OSX but I'm having trouble recording knob movements into Pro Tools 6.4. While The 3 knobs work fine and control sound, the knob movements aren't being played back and I don't know what CC#s these knobs are assigned to. On my NL2 everything is hardwired and I know that the filter cutoff on it is #74 but is it similar on the micro? How can I record midi NRPNs with these 3 knobs? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Novation SL49/Remote Zero
Mophox4, Nord Lead 2, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ |
cappy2112
Joined: Dec 24, 2004 Posts: 2466 Location: San Jose, California
Posted: Fri Dec 14, 2007 9:55 pm Post subject:
Re: Recording Micro knob movements Subject description: Recording Micro knob movements |
Gothboy wrote: | On my NL2 everything is hardwired and I know that the filter cutoff on it is #74 but is it similar on the micro? How can I record midi NRPNs with these 3 knobs? |
No, the knobs do not have dedicated CC's assigned, and neither do the settings in any patch. The reason for this is that each patch is different, and it's quite possible that a given patch may not even have a filter but still use CC 74 for another parameter.
As far as being able to send NRPN"s from the micro, I'm not sure if this is possible. The NM1 doesn't have a flexible midi implementation. I'm not sure the G2 could send NRPN's either, even though it has a much more powerful midi implementation.
Your best bet would be to find some free (or cheap) software that will map standard CC's to the NRPN's that you want to send from the NM.
I know there is software for Windows to do this, and I would most certainly expect something for the Mac as well.
There are a few Mac users on electro-music, maybe one of them will reply with the name of some Mac software that will do the mapping.
You should also do a search from the highest level down, for Mac software, Mac midi , and other combinations. Maybe you will find some of these posts.
It almost sounds like the problem is on The pro tools side.
Can you try using standard CC's, and see if these can be recorded from the micro into pro tools?
Why do you want to use NRPN's instead of CC's? |
Gothboy
Posted: Sat Dec 15, 2007 7:35 am Post subject:
cappy2112 wrote: | No, the knobs do not have dedicated CC's assigned, and neither do the settings in any patch. The reason for this is that each patch is different, and it's quite possible that a given patch may not even have a filter but still use CC 74 for another parameter. |
After doing some backward thinking and looking through the manual again this part was clear. Because the modular system is so flexible and each physical knob can be mapped to any knob in the software they of course are not hardwired so silly me on that one! But there must be some way of twisting a physical knob and having the movement recorded into not just Pro Tools but on any sequencing software.
cappy2112 wrote: | It almost sounds like the problem is on The pro tools side.
Silly me again...... ! I think I'm getting my NRPNs and CCs mixed up. My system seems to be working properly though, as I tested it using my M-audio controller and the Gforce Oddity. I have knob 9 on it bound to the Oddity VCF cutoff and I recorded a knob move into PT. On the PT midi track I then added CC12 as a controller and I can then view the knob movements recording. So PT's working.....I just want to be able to do the same with the knobs on the micro. So I guess I'm just talking about CCs here. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ Last edited by Gothboy on Sun Dec 16, 2007 12:19 pm; edited 1 time in total |
cappy2112
Posted: Sat Dec 15, 2007 12:48 pm Post subject:
Gothboy wrote: |
recording. So PT's working.....I just want to be able to do the same with the knobs on the micro. So I guess I'm just talking about CCs here. |
Can we eliminate all of the complexity from this equation first?
1. I don't have pro tools nor a Mac.
2. Try to find some simple free midi monitor software that displays everything coming into it.
Connect ONLY the micro to the midi in port on the mac, and make a simple patch with just a few modules. If you are using a midi patch bay, then bypass it for the moment. (You wouldn't be the first person to get the midi in/out's backwards or confused with the PC in/out ports. I use color color coded cables to help prevent this
Assign a few different cc's to the knobs on those modules, and tweak away. Lets verify the micro is transmitting first, then worry about getting those settings recorded later. You may have to go into the editor menu settings to enable something to get this working.
I'm at work now, so I'm not in front of the manual or the micro, so I can't guide you better. |
Gothboy
Posted: Sun Dec 16, 2007 10:05 am Post subject:
Thanks Cappy for all your help so far, nice of you to pitch in....even from work!
This morning I re-cabled everything between the Micro and the midi interface. I've got the micros' regular midi in and out on port 3 of the interface and the editor in/out on port 4. Using just the Macs' Audio midi setup and completely eliminating Pro Tools from the testing tells me that midi is being sent to the micro on port 3. Same with port 4 but here's the thing, knob movements are only being sent to port 4....the editor....to control the knobs in the editor. So the question is how can knob movements be also sent on port 3. Can they only be sent on one port at a time? Seems to me that both sets of midi in/outs on the micro should be able to do both. I guess this question has to be answered by anyone who is using the micro with a sequencer, any sequencer, not just Pro Tools.
Can the micros' knobs send midi on both of it's in/outs or is it just the editor outs? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Dymaxion Vehicle Music at www.dymaxionvehicle.com/ Last edited by Gothboy on Sun Dec 16, 2007 11:55 am; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sun Dec 16, 2007 10:21 am Post subject:
Gothboy wrote: | Can the micros' knobs send midi on both of it's in/outs or is it just the editor outs? |
It sends knob movements as CC messages on the regular MIDI port.
That you see activity on the editor port as as well is because the editor's (virtual, on screen) knobs rotate along with the physical knobs, but those are not usable CC messages for other equipment. The editor connection is only usable for the editor and for nothing else.
Here is how to set things up :
In the editor right click on a knob on a module and assign the virtual knob to a physical one. Then right click again and also assign the virtual knob to a MIDI CC number. Now when you turn the physical knob MIDI CC messages will be put out on the regular MIDI output and that same CC message will be listened to through the regular MIDI input. _________________ Jan
Gothboy
Posted: Sun Dec 16, 2007 12:18 pm Post subject:
As I was outside shoveling snow(we're getting hit yet again with a storm here in New England ) I was thinking that if you right click on a knob in the software there must be a way to assign a CC# to that knob and then if a physical knob is assigned to the software knob......... Thanks Jan, I'll try this out and post results. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Audio files: 278
Posted: Sun Dec 16, 2007 12:21 pm Post subject:
You're welcome, and you could send some snow this way, I'd love some _________________ Jan
Gothboy
Posted: Sun Dec 16, 2007 1:55 pm Post subject:
Why the heck would you want snow? It's only useful for skiing.......! There's now about 12-15" here, you can have it all, I have no use for it. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Audio files: 278
Posted: Sun Dec 16, 2007 2:12 pm Post subject:
Gothboy wrote: | Why the heck would you want snow? It's only useful for skiing.......! There's now about 12-15" here, you can have it all, I have no use for it. |
We don't have snow very often, and when we have it's usually just an inch or so max. Dunno, it's good for my mood, and I thought you were having too much anyway...
Got it working? _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Audio files: 278
Posted: Sun Dec 16, 2007 2:55 pm Post subject:
Wout Blommers wrote: | Here's a picture of winter 2005, in your neighborhood. Is this an inch max? |
Nope that was a bit more and I remember it took me a few hours to get home that day where it should take less than half an hour, but I said "usually"
Yup new avatar, got nostalgic and picked an image from grandma's time and grandma's home _________________ Jan
Gothboy
Posted: Sun Dec 16, 2007 3:33 pm Post subject:
Anyway......... back to my issue. I assigned knob 1 to a filter cut in a patch, then using another right-click I assigned the filter cut to cc19. Then I recorded a knob turn over a midi part in PT and added cc19 as an added controller but the knob turn still isn't playing back. I know midi is getting to the interface because when I turn the knob after the assignment the right interface port flashes. Hummm......so it's pointing now to PT as being the culprit but this works with the NL2 and my softsynths...?
I've got midi merge on, the micro is in the instrument input list and PT isn't screening any midi stuff out. I should be able to do this in a sequencer right? I'd post this on the DUC but no one there would know about the micro....only you guys. So I'm a little stuck.....midi, sound, all seems to be going through PT but not the knob turns. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Audio files: 278
Posted: Sun Dec 16, 2007 3:40 pm Post subject:
Gothboy wrote: | Anyway......... back to my issue. |
Yes sir, you are right, sorry for the OT.
What you did should work and the indications seem good. Time for a PT expert to kick in I guess ... erm .. one thing left I can think of .. the MIDI channel, is that set OK? _________________ Jan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 16, 2007 3:44 pm Post subject:
Gothboy wrote: | ... I know midi is getting to the interface because when I turn the knob after the assignment the right interface port flashes. Hummm......so it's pointing now to PT as being the culprit but this works with the NL2 and my softsynths...? ... | What causes the flashing? It could be the Synth MidiOut, like the NordLead2, but it could also be the PC Midi Out, the connection of the synth with the Editor...
Wout |
Gothboy
Posted: Sun Dec 16, 2007 3:51 pm Post subject:
Blue Hell wrote: | [ the MIDI channel, is that set OK? |
Midi channel is 1, as the micro only uses channel 1 right? The flashing is the midi sent to 3 which is the port the micro is on, the editor is on 4. What do you guys use, Logic or something? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 16, 2007 3:55 pm Post subject:
Gothboy wrote: | Midi channel is 1, as the micro only uses channel 1 right? | No! You can set the MidiChannel by using Shift and turn the knob labeled 'Midi'. The LCD will tell you which channel...
[Manual 3.01 - Page 61]
Wout |
Gothboy
Posted: Sun Dec 16, 2007 4:01 pm Post subject:
Doh! Maybe that's it. I haven't even thought about that. Allright I'm not in front of it right now I'm making dinner......I'll check it ASAP but I never changed it so I'm not counting on this as being the prob but......famous last words, eh? _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Gothboy
Posted: Sun Dec 16, 2007 7:19 pm Post subject:
All set now! The micro was on the right midi channel after all, what I didn't do was have "All" selected in the midi tracks' input and the micro as it's output. I've never quite understood why "All" has to be used as a generic midi input for control and not the specific instrument itself from the drop list but it's working now and I know what I did wrong. I've got all three knobs doing 3 different cc controls in a midi track. Hoorah! Thanks guys. _________________ Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Audio files: 278
Posted: Sun Dec 16, 2007 7:24 pm Post subject:
Gothboy
Posted: Mon Dec 17, 2007 5:55 am Post subject:
16 GB Ram
10.8.5/El Capitan
