Clangora jam
Page 1 of 1 [17 Posts]
creatorlars
PostPosted: Sun Jan 20, 2008 9:49 pm    Post subject: Clangora jam Reply with quote  Mark this post and the followings unread
Got my Clangora finished tonight. Here's a quick jam with just the Clangora triggered by my Midibox SEQ3 and lotsa knob tweakin'. I never was able to find any soundclips of the Clangora online before building this thing, so hopefully this is representative of some of the wide range of sounds it can make... the Clangora was exactly what I was looking for... thanks Thomas!
clangora.mp3
 Filename:  clangora.mp3
 Filesize:  3.1 MB
 Downloaded:  987 Time(s)
PostPosted: Mon Jan 21, 2008 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice, indeed! thanks for sharing.
Tech Budday at Random*Source
bugbrand
PostPosted: Mon Jan 21, 2008 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoah! That's cool!
Darn, I want one now!
http://www.bugbrand.co.uk
bubblechamber
PostPosted: Mon Jan 21, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds great, I really need to build a couple of these, too. thanks.
Photon
PostPosted: Mon Jan 21, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds crazy! Great job.
I finished my frac vers. a couple months back and forgot to follow up. Here's some photos. Wiring was a bit cramped, but it worked great from first power-up.
Really looking forward to the Mega Percussive Synthesizer Very Happy
 Filesize:  130.16 KB
 Viewed:  414 Time(s)
loss1234
PostPosted: Tue Jan 22, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
i love the way you mounted the PCB....
where do you get those standoffs? and what is that piece of material that you are attaching the pcb to? it looks really good and i have been having some major problems getting my standoffs to work quite right...
you using a 4u wide frac panel?
couple of questions
1. did you etch the pcb yourself? it takes like 4 566's right?
hmmmm seems like an awesome module. and great graphics too!
Photon
PostPosted: Tue Jan 22, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where do you get those standoffs? and what is that piece of material that you are attaching the pcb to? it looks really good and i have been having some major problems getting my standoffs to work quite right...
couple of questions
thanks.
The bracket is just aluminum. I think it's .030" thick. bent and notched to allow clearance for the bottom of the adjacent pots. (its pretty tight back there)
the standoffs are from mouser. numbers here:
561-187TAB
561-250TAB
561-312TAB
561-375TAB
561-437TAB
561-500TAB
561-562TAB
561-625TAB
Yes I etched the pcb myself... kitchen sink technology. Very Happy
If I remember right it takes 3 566's and a NE570 compander.
The panel is 4.5" wide. (frac and a half)
I'd say this is one of the more challenging things I've built so far.
Alienation
PostPosted: Tue Jan 22, 2008 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent demo!! Shocked
I've become a TH fan and this is on the etching schedule. Cool
Thanks again.
creatorlars
PostPosted: Tue Jan 22, 2008 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm glad you guys liked the clip -- I must give credit to my bandmate Shane English for the knob manipulations.
I will take some pictures of my module tonight or tomorrow. The panel is in the Moog format, double-width.
Mine was a self-etched board as well. The PCB layout is nicely spaced out and very easy to work with, even though it wasn't the cleanest etching job on my part. The module worked right away after fixing a couple of easily discovered broken traces. Just be sure you read the article text about the panel-mounted components.
I got my NE570 from Small Bear, and my 3 NE566's from Electronic Goldmine. Everything else I ordered from Mouser (aside from general resistors and caps I had lying around already.)
Alienation
PostPosted: Tue Jan 22, 2008 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where did you get the knobs for your panels? (Photon and Creatolars)
I'm trying to scale the GIF so I can get it printed onto pnp blue. It looks like it needs to be reduced....again. Mad
creatorlars
PostPosted: Tue Jan 22, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
How I reduced the graphic is by opening the layout in Photoshop and adjusting the settings in the "info" tab to display Inches. Then use the selection tool to select an area between two pins in the DIP sockets... resize the image until you get exactly 0.10". You may have to resize the image to 300 dpi before doing this. Of course, I realize not all of you have Photoshop -- but I'm sure there are some free graphics utilities out there that will do this much.
I really like Eagle Plastic's colored cap knobs w/setscrews. Mouser sells them in four different colors for around $0.95/each, but I went to All Electronics, which has the red capped ones for $0.75/each and bought 100 to get a price break of $0.65/each. I've been using these with Alpha 16mm smooth shaft panel-mount pots (not super cheap, but I like them and I want to keep using consistent parts for my projects.)
These are the knobs:
http://www.allelectronics.com/cgi-bin/item/KNB-124/310/KNOB_FOR_1_4%22#34;_SHAFT_.html
I'm building a pretty colorful unit (each module is duo-color silkscreened according to designer/origin -- Turquoise/Pink for Thomas Henry's designs.) So in order to get colored knobs that match my silkscreen colors exactly, I have to paint the knob caps. I tried several methods but the paint always wore off. Right now I use a small flathead screwdriver to pop off the caps (they are glued on initially), then I prime them with a white primer made for plastic model figures (expensive stuff but worth it), and then I paint them with Modeller's paints. (A good brush is a must, to get it on smoothly.) After that I clearcote with matte varnish and use epoxy to glue the caps back onto the knobs. The white primer allows for some really bright colors and the paint is showing no signs of wear after handling. I'll get some pics up soon.
Thomas Henry
PostPosted: Tue Jan 22, 2008 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do I really come across as a pink sort of guy?
Anyway, very nice samples. What really amazes me is that when I do these circuits I'm thinking strictly percussive sounds, and then guys like you and Scott (who did something similar with the MPS) turn around and come up with all sorts of tonal things I never would have thought of trying.
Good job!
Thomas Henry
Photon
PostPosted: Tue Jan 22, 2008 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
The knobs are from Allied, Davies Molding 1900-H. They are unfortunately on the pricey side. I've already burned through the 100 I bought last year Shocked Sad Shocked
I used a photocopier to reduce the pcb image until the all pins of an IC socket lined up with the corresponding pcb traces. I seem to remember it being around 64%, but I'll have to check my notes.
creatorlars
PostPosted: Wed Jan 30, 2008 5:27 pm    Post subject: Another jam... Reply with quote  Mark this post and the followings unread
Here's another quick live jam with the Clangora + some reverb/EQ. Still workin' on those pics.
clangora2.mp3
 Filename:  clangora2.mp3
 Filesize:  2.28 MB
 Downloaded:  775 Time(s)
Alienation
PostPosted: Wed Jan 30, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another interesting jam.
Thanks for doing these, I plan on etching the pcb for this in a week or so.
I'm hearing alot of interesting sounds out of this.
Thanks again. Very Happy
creatorlars
PostPosted: Thu Jan 31, 2008 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
No problem! Once I get a couple more modules added, I'll post some more with everything altogether (808 kick+snare, 909 kick, clangora, UD-1).
Nah, but unlike my 808 clones, you don't have a predefined color schema to work with!!! Smile Don't worry, turqoise/pink is one of my favorite color combinations, so it's a compliment. (Blame alien worlds in early CGA/EGA computer games for that one.)
Scott Stites
Audio files: 96
PostPosted: Thu Feb 07, 2008 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Holy cow, how did I miss this? Very, very cool! I haven't even downloaded the second one yet. 1:30 AM or thereabouts, on dial-up, I'll have to wait til tomorrow.
But, man, very Clangorlicious, indeed! Cool
Thanks for posting this,
Scott
My Site
