Wave-Goo
Page 2 of 2 [26 Posts]
Goto page: Previous 1, 2
JovianPyx
Audio files: 224
PostPosted: Sun May 04, 2008 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
usw wrote:
weird...I'm getting a very different result (sounding like a crossfade) with your function (sweep is reversed) Shocked Are you using very short tables for your sine/cosine waves ?
http://perso.numericable.fr/usw/electro-music.aiff
This doesn't seem different to me, other than the fact that the sweep is reversed. But as I said, with this identity, I can't say if it's the same as a pan or not. I looked at the math and it ought to be fairly easy to see if it's a pan. In fact, a bit of algebra should be able to transmute one into the other - but I'm unable to do that (and I'm also no math wizard either).
Anyone else?
I'm pretty sure the sin(3u) to sin(u) is NOT a pan, since you can hear sin(2u) in the center of the sweep.
Time flies like a banana.
corruptio optimi pessima
