synth_ollie
Posted: Tue May 20, 2008 12:50 pm Post subject:
a question to cgs digital noise users |
do you ever use the wh/pnk trigger outputs ?
I have a very limited frontpanel space and it seems like I
will have to choose between the trigger outputs or the leds,
and its always nice with some visible indication so.... ?
cheers
OLLIE |
andrewF
Posted: Tue May 20, 2008 4:23 pm Post subject:
for me, the digital outs get used more than the noise outs.
You could take the middle path, have one led and one digital out. |
fluxmonkey
Posted: Tue May 20, 2008 4:33 pm Post subject:
i use both filterd outs all the time... pnk out at slow clock settings to FM VCOs is particular fave. i wouldn't cut them. the 2 digital outs sound the same to me, so you might drop one; and i really don't think the LEDs provide much (i didn't implement them). also: don't omit the external CV and Clock ins... these are insanely useful.
b |
Cat-A-Tonic
Joined: Mar 24, 2008 Posts: 42 Location: Yokohama, Japan
Posted: Tue May 20, 2008 7:00 pm Post subject:
digital noise Subject description: digital noise |
Agreed, you don't need LEDs just jack up everything.
CV in, Clock in, pink, white, 2x digital, rate knob.
Fits in a single size Frac panel.
I love sending one channel of the Dual Drum to the Klangwerk, Using the White noise as a carrier (ext. freq), and the Digital noise as the CV for the carrier wave. Perfect Snare Drum. |
zthee
Posted: Tue May 20, 2008 11:51 pm Post subject:
Ah, this thread was really usefull. As I just ordered me a digital noise pcb! |
otherunicorn
Posted: Wed May 21, 2008 1:13 am Post subject:
bbob wrote: | i use both filterd outs all the time... pnk out at slow clock settings to FM VCOs is particular fave. i wouldn't cut them. the 2 digital outs sound the same to me, so you might drop one; and i really don't think the LEDs provide much (i didn't implement them). also: don't omit the external CV and Clock ins... these are insanely useful.
b |
The two digital outputs do sound the same. If you are going to have just one, either is as good as the other. The purpose of having two is for when you want to use both at once - then the difference is of some value. _________________ http://www.cgs.synth.net/ |
synth_ollie
Posted: Wed May 21, 2008 3:07 am Post subject:
thanks all for your replies
I think I´ll go for one dig. out and one led
cheers
OLLIE |
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Wed May 21, 2008 6:59 am Post subject:
BTW, smallest (non SMD) LEDs currently available seem to be 1.8 mm, although maybe not so easy to find. _________________ Jan
synth_ollie
Posted: Sun May 25, 2008 9:06 am Post subject:
well, it was really more a question of how I would use the
number of pre drilled holes on the panel the best way
I have replaced the ordinary noise gen. in one of my
m-150 (roland 100m) modules with a cgs digital noise,
here´s how it finally turned out
edit: a short soundclip sweeping/modulating the int. clock
http://www.analogue.org/roland100m.ce/media/dng.mp3 |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Sat May 31, 2008 3:37 am Post subject:
Re: digital noise Subject description: digital noise |
Cat-A-Tonic wrote: | Agreed, you don't need LEDs just jack up everything.
Indeed. It even fits in a single size Frac with 5mm LEDs.
Check:
http://www.casia.org/modular/img/casia_ms01_080305.jpg
Top row, fifth module from the left. _________________ http://www.casia.org/modular/ |
synthetic
Joined: Jun 02, 2007 Posts: 76 Location: Glendale, CA
Posted: Mon Jun 02, 2008 9:18 pm Post subject:
Thanks for the MP3, I was wondering what this thing sounded like. Now I know – every videogame I played from 1985-89. |
zthee
Posted: Tue Jun 03, 2008 3:08 pm Post subject:
I jused finished my module! Yay!
Sounds great! (As great as noise can sound ).
http://zthee.vantage.ch/31.mp3 |
Solid Rate Studios
Posted: Thu Jun 05, 2008 4:20 pm Post subject:
My opinion on the CGS Digital Noise... It's a great Noise source, for sure! But, it's also a great random trigger out x3 when synced to an external clock! Try it, you'll like it!!!
-dJ dAb
CGS PSYCHO LFO / 2 RADIO SHACK LO-FI SAMPLERS / CGS DIGITAL NOISE
FULL RACK
Sine
Joined: Sep 10, 2007 Posts: 111 Location: Netherlands
Posted: Fri Jun 06, 2008 4:37 pm Post subject:
Ooohhh ....
Now I am going to HAVE to get me one of those !
And I'm already low on free rack space ... O well |
