 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
June-o
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Jul 22, 2004 1:07 am    Post subject: June-o Reply with quote  Mark this post and the followings unread
Here's an Juno style synth. Similar signal flow of a real juno, ie 1 triangle lfo controlling vibrato/filter/pwm, 1 env controlling filter/amp/pwm (positive or negative), 1 multi oscillator (saw/pulse/sub), 1 noise oscillator. Chorus gives it a real Juno-y feel, although not quite as noisey Wink. It Uses 2 delay modules modulated by the triangle LFO. Each delay mixed with original signal and panned left/right. Although it can't do the famous "what the..?" (charly/hoover) patch, alot of juno-y sounds can be made (like the basses and a few of the leads). I'm thinking about adding in the "chord" function of the alpha juno series, might post an update tomorrow. Enjoy!
PS, when the cutoff is low and the chorus is turned on, does anyone else get clicks in one of their speakers? And yes, I have updated to 1.22. It's bizare, both delay modules are exactly the same, being modulated the same way yet one clicks as it's being modulated....
Juno.pch2
 Filename:  Juno.pch2
 Filesize:  2.54 KB
 Downloaded:  2098 Time(s)
