  DarthBuddha Meat Pinata http://meatpinata.com
Modular software synthesisers
Page 1 of 1 [14 Posts]
bladerunner
PostPosted: Fri Mar 27, 2009 4:46 am    Post subject: Modular software synthesisers
Subject description: discussion about modular software synthesisers
hi everyone,
i am currently working on a dissertation for my music technology degree exploring modular software synthesisers/synthesis. My main area of research concerns the differences between modular synths and fixed path synthesisers. I will be looking at the sonic advantages of a modular approach to synthesising sound. i would be very interested to hear the views and opinions of anyone who uses environments such as MAX/MSP, pure data, bidule, analog box etc.
looking forward to your replies Smile
bladerunner
PostPosted: Tue Apr 21, 2009 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
i see that no one has replied Sad to be honest it was a bit of a vague subject area and far to wide to research thoroughly. i have slightly changed the area that i will be researching now as what i had in mind when i first had the idea was the ways in which you can control synthesised sound linearly. i have since realised that this is more to do with automating amplitude and filter parameters so my research will head in this direction now...
EdisonRex
Audio files: 157
PostPosted: Tue Apr 21, 2009 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
it was a bit vague. I still think "automated control" is vague but if you want to discuss it more, maybe someone can say something more useful.
Garret: It's so retro.
PostPosted: Tue Apr 21, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's still very vague. Shocked Perhaps you should give us your opinion first, and then we'll share our views in return, and see if we agree or not.
As you are no doubt aware, music and sound creation are very personal subjects. Very Happy
ACHTUNG!
bladerunner
PostPosted: Wed Apr 22, 2009 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
can you sense i am struggling a little on this?! Confused yes you are right, it is vague. basically, i am doing a 3000 word research project that is designed to prepare us for a 10000 word dissertation. although i have been writing music since i was around 12 i have only fairly recently started using synths to make completely original patches for my own music. i have been trying to come up with a good synthesis based research idea that will be both interesting for the reader and serve to bridge a gap in my own knowledge of synthesisers/synthesis. modular synthesisers are definitely something i know little about hence the original idea, but... perhaps i have bitten off more than i can chew. perhaps i should do a more general research project on simply 'modular synthesisers' (probably just trying to be clever with the whole modular vs fixed signal path thing!). the 3000 worder doesn't have to be too specific as such but the 10000 worder will have to be a lot more focused and thesis based. i was hoping that my initial research (the 3000 word one) will reveal some area that i can focus on for the 10000 word one... hope that all makes sense! ...and apologies for the vague thread Embarassed
i will spending the rest of my day reading the synthesis section of curtis roads 'the computer music tutorial'. hopefully this will trigger some more constructive thought...
telstarmagikistferrari
Audio files: 43
PostPosted: Wed Apr 22, 2009 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't hesitate to take a look at Synfactory (do a google search) as a simple example of modular synthesis on a PC.
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Wed Apr 22, 2009 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have all my resources, either with me or otherwise Wink , but I do remember a fair amount of material regarding Moog's approach to subtractive synthesis, as a method of *reproducing* realistic sounds. At least, that was the fundamental reason for choosing the methods he did, in that it emulated what was happening with physically based wind/string/wood type instruments. It is evident in all the presents and programming techniques of the time. Same for the Karplus-Strong algorithms, in emulating a string-resonant body instrument. So maybe you can use that in your own discourse...that fixed path synthesis tends to originate in trying to emulate a specific sound.
Also, you should try "Analog Box", here:
http://www.andyware.com/abox2/index.html
oisin
PostPosted: Wed Jun 17, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
it could be interesting to not only look at the sonic advantages to modular synthesis, but also the technical (workflow?) advantages; the way creating a new patch from scratch is different from working with hardwired machines..
fac
PostPosted: Wed Jun 17, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm a modular freak... I have a small analog modular (dotcom) and a Nord G2, but have also played with PureData, Audiomulch, and VAZ Modular.
I would say that modular synths/enviroments themselves are very different from each other. Here are a few examples:
Audiomulch uses higher level modules and is mostly oriented to live performance. It has very little sequencing abilities, but compensates it with some powerful automation and parameter-morphing tricks.
PureData (and probably also Max/MSP) use low-level components and are great for working with samples, complex sequencing, algorithmic/generative music, etc. However, because Pd is so low-level and makes no assumptions about the patch one is constructing, it isn't easy to obtain high-quality sounds out of it. One must be very careful with aliasing, clicks and pops (usually produced by envelopes being too fast), quantization/stepping, etc.
Vaz Modular is great for synthesis and basic sequencing. It has a very powerful sound (much better than Pd or Audiomulch), and an interesting interface that doesn't try to emulate real patch cables. It's more like a hardware modular, but with the power and flexibility of a software enviroment.
What's great is that you can, for example, load VAZ Modular as a VST inside Audiomulch, thus combining the advantages of each. I believe you can also export Max/MSP patches as VST's, and probably load VST's in a Max/MSP patch as well. This kind of interactions results in an experimental framework that could never be achieved with hardware synths.....
On the other hand...
I also love simple hardwire synths for their immediacy. Sometimes, all you want to do is a simple bassline and tweak the cutoff. This is, of course, possible within a modular enviroment, but then you'll start wondering what if you also modulate this with that and control the modulation depth with this knob, and so on.... suddenly, something that should have been so simple becomes a monster with a dozen parameters that affect the sound in ways you hardly remember.
My music: http://cdbaby.com/all/fac
Grizzle
PostPosted: Fri Nov 27, 2009 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
It'll be difficult to get 3000 never mind 10000 words out of the difference between fixed and modular synths.
The obvious differences are:
A fixed synth quite often has a keyboard attached and reduces what can be done to what is most frequently done. Reducing the control complexity reduces the complexity overall. It is easier to learn, to use, to control. Also though the sounds that can be generated are often less complex. Semi-Modular a mix between fixed and modular path synthesis offers the best of both worlds.
A fixed path synth is usually a performance solution. Often the come with keyboards and just enough controls to make them useful. Have a look at the Moog Lil Phatty which appeals to many musicians who just want a good synth sound. Many traditional musicians are put out by technical synth language and really are more focused or performance rather than sound design.
A modular synth can be as complex or as simple as you like. Modular synths can fill a large room or they can be simple problem solving solutions such as when X happens do Y.
Everytime you unpatch a modular synth you essentially have a brand new synth and have to rewire it to create each new patch. A patch could be an emulation of a particular type of fixed path synthesizer, or a just a simple sound, or an entire piece of music, or even a type of sound processor. It is more difficult to think in these terms in a fixed path synth where most patchs are simple sounds.
A fixed path synthesizer has a fixed function, that being to make musical sounds. As a modular synthesizer offers low level components these components can be easily re-purposed to perform others tasks. A modular synthesizer can be thought of as a kind of computer with comparators, logic gates, filters, timing circuits, gates etc. More powerful software modular synths like Max/Msp can easily be used for education or research purposes. Max offers many of the functions of traditional programming languages eg. the ability to create, manipulate and store lists, the ability to display data graphically, the ability to take in sensory data from the outside world etc...
You would probably have more millage dealing with issues of control. it is a wide area taking in ideas of Pitch control (quantizers and scalers), randomization and probability. You can talk about motion tracking and gestural control, haptic feedback, bio-sensing, augmented reality installations.
anyways just a ramble before bed...
hope it's of some use.
www.myspace.com/grizzlemusic
PostPosted: Sat Nov 28, 2009 7:15 pm    Post subject: Re: Modular software synthesisers
The obvious difference is that using the tech from the late 60s/70s the poor bastards who decided to manufacture "synths" would obviously have to figure out some way to contain the madness and batter together products that hopefully could sell in numbers. The various breeds of the modular synth kind were specialist devices back then and not an option at all until a lot of the good stuff started to hit the second hand market around 1980. Roland did of course try to figure out the modular synth segment with the 700 and 100m systems, but as the 700 was intended to be another upmarket product ( mainly targeting universities and high end studios ) and thus was still a pretty expensive package and they never really managed to get the System 100m out to the music shops in numbers before they folded the product line.
Korg attempted to tune in to modular synthesis with the MS series, but few really caught on to the whole concept. Some of the devices were impossible to get hold of and if you ordered one it could take nearly two years or more before the shop got shipped say an MS50 to go with the rest of the MS gear you already had bought.
So, the "difference" would from my viewpoint mainly be about the harsh realities faced by the manufacturers. Modular synths weren´t something that could sell in numbers because of manufacturing time and manufacturing cost and there wasn´t a huge market for them anyway.
Even now we see that software modulars aren´t really that exciting. There are few good commercial ones, and the fact that there are many freeware modular software apps around suggests that free distribution is the most sensible as they would not sell in numbers no matter what you did. Like, if there had been a huge interest in modular synths then you would see ads like: Buy this goddamn Volkswagen and get a free lifetime Reaktor site license. Shocked
As for the actual concept of modular synthesis, this is another thing altogether. Fact is that a fair lot of the mid era hybrids and digital synths soon started to actually sport an architecture that can best be described as "modular", but this did most of the time not really show on the actual interface of the product. OK, a number of the samplers did in fact show ( if you did some menu diving ) that the internals were indeed quite modular of sorts, but the point is that the market for these things only asked for a high number of sounds that were easy to access.
The Clavia NM range actually came about as some sort of accident. For some silly reason they figured that they could repackage a refurbished version of the prototyping system they used for their "fixed path" digital synths into a hardware +software suite. Brilliant instruments! -And the market hated the idea. Clavia finally folded the second generation G2 range not long ago.
I guess you could rewrite
into something like
...modular synths and "something that possibly might appeal to the potential buyers out there..
BTW, if you want to trace the history of electronic instruments ( in the sense of marketable products ) you would have to take a look at all the pre-Moog organ stuff. And there are some incredibly interesting ( and forgotten ) devices out there. And then follow the Moog path into the synth/ organ / string synthesis/ and electronic piano segments ( which were indeed different segments - but they converged in the 80s ).
Modular synthesis never went away, and it is more popular and accessible now than it used to be, but it is still an aquired interest for demented minds. Laughing
Flickr
PostPosted: Sat Nov 28, 2009 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
As for the obvious limitations of early fixed path synths, I guess early mass market appeal focused on the Walter Carlos sound. Sure, she used a modular system, but vendors needed to stuff some sort of essence of those sounds into simple machines ( like the Roland SH 1000 class of synths ). As several companies struggled with figuring out how to do this, the musicians of the era tried to make sense of whatever it was they had bought. And when these sounds were featured on popular LPs then this was what the market really wanted.
The standard keyboard rig of the mid 70s would usually be something like
1. organ
2. electric piano
3. string synth
4. synth ( usually a Minimoog/Odyssey/Cat2 class instrument ) or something like the Soloist.
Big acts would always bring upmarket gear.
Flickr
EdisonRex
Audio files: 157
PostPosted: Sun Nov 29, 2009 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, Stein has it. Back in the day, a modular cost more than a house. In 1972, an ARP 2500 could set you back 25,000 1970s dollars. A car was only about $3000 then. To have the Minimoog available for less than what a car cost was fairly major; likewise those early japanese and other contemporary performance based instruments available for a fraction of the cost of a modular, priced near enough to other keyboards, was good marketing, if anything.
Al Pearlman used to give his performance synthesizers away to famous artists... why one say a lot of Odysseys around. It did tend to get the sound out too.
bladerunner
PostPosted: Sat May 01, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
first of all, apologies for abandoning my own thread! thanks to everyone who replied - it certainly helped me to realise that i didn't have much of an idea for a final paper Embarassed . i ended up carrying out an assessment of the impact of algorithmic software environments like MAX MSP/PD on contemporary electronic music composition. by my own admission it wasn't very good and i got a 57% for the paper (and i was really suffering from the stress of it all by this point - it was quite evident in my paper!) but... nearly all of my modules were marked at 66 - 91 % and i came out at a safe above 70% average and i got a first overall so all is good! so, thanks again Smile i intend to hang out here more often now.
