sven kalmar
Posted: Sat May 16, 2009 2:41 pm Post subject:
monster analogue patch? |
| has anybody made a patch in mix mode , where you use the same basic monosynth patch but all osc tuned diffrently, like a moog modular with 9 osc...or whatever... |
Shreddie
Posted: Sat May 16, 2009 4:15 pm Post subject:
| If it's the same basic patch with nothing more than oscillator detune, I just put the Andromeda into unison... No need for mix mode. |
sven kalmar
Posted: Mon May 18, 2009 12:33 am Post subject:
monsterpatch |
| i would have to copy the patch some times. lay them up in mix mode , and tune each of them differently, i like to do this on the evolver, moog. could be interesting....at least weird...the a6 can be extremely weird... |
jonkull
Joined: Sep 22, 2006 Posts: 162 Location: Burbank, CA
Posted: Mon May 18, 2009 10:36 am Post subject:
Or you could switch on unison which will de-tune them for you.
The only reason I could see for doing this in mix mode would be if you were layering different patches. _________________ http://recoilsun.bandcamp.com/ |
Shreddie
Posted: Mon May 18, 2009 2:35 pm Post subject:
| jonkull wrote: | | Or you could switch on unison which will de-tune them for you. |
Which is what I basically said. |
jonkull
Posted: Mon May 18, 2009 3:07 pm Post subject:
| Shreddie wrote: | | jonkull wrote: | | Or you could switch on unison which will de-tune them for you. |
Yes, I was reiterating what you said based on his response to your response.  _________________ http://recoilsun.bandcamp.com/ |
sven kalmar
Posted: Mon May 18, 2009 4:47 pm Post subject:
ok i m trying to do is make a monophonic patch with lets say 6 osc tuned to a big chord.. it tried today and its interesting...then i could change from prog to prog and tune the to different chords it would be like a monster mono synth with 16 independent osc,s perhaps both me and the synth will go insane soon.....  |
sven kalmar
Posted: Mon May 18, 2009 5:00 pm Post subject:
imagine a chord made of 16 different notes every time you hit a key...
propably wouldnt make too much sene musically.. What does mike peake think...will it drive the A& insane....? thanks for all the great work you have done , MIKE! fabulous...  |
jonkull
Posted: Mon May 18, 2009 5:49 pm Post subject:
| sven kalmar wrote: | | imagine a chord made of 16 different notes every time you hit a key... |
Interesting but couldn't the same be done by simply switching your mono patch to poly and making the chord with the 'chord' button that's near the pitch/mod wheels? Though I suppose that would require 16 fingers or some other way of keeping the keys down to make the first chord.  _________________ http://recoilsun.bandcamp.com/ |
sven kalmar
Posted: Mon May 18, 2009 5:57 pm Post subject:
yes i guess so.. with my method i can jump from prog to prog and tune them really fast...i tried with a typical moogish prog copied it 4 times
made a mix.. unison off , mono, then i tried to use osc 1&2 for prog 1
34 for the next..then add some modulation to a synced osc 2 etc etc
---all oscs tuned differently ..weird shit..  |
Shreddie
Posted: Mon May 18, 2009 8:16 pm Post subject:
| jonkull wrote: | | Shreddie wrote: | | jonkull wrote: | | Or you could switch on unison which will de-tune them for you. |
Yes, I was reiterating what you said based on his response to your response.  |
Yeah, I know, that's why I was confused!
| sven kalmar wrote: | | ok i m trying to do is make a monophonic patch with lets say 6 osc tuned to a big chord.. |
Now it all makes sense! |
sven kalmar
Posted: Thu May 21, 2009 6:18 am Post subject:
it works and is interresting....weird though...  |
