<on air> faux pas quartet and friends Music From Last Thursday
Bug fix: pssshhhhttt!
Page 1 of 1 [5 Posts]
Inventor
Audio files: 236
PostPosted: Mon Jun 08, 2009 10:30 am    Post subject: Bug fix: pssshhhhttt!
Subject description: Bug in my brain...
Hi folks, I've got a quandry here. I wanted to make a drum machine based on kijjaz's drumset, ok. So I thought I would do a signal intensity level on the output and if the signal got low i would hit a drum. Well, all I get is constant drum beats. Please have a look at my code and tell me what i'm doing wrong, thanks.
Les
Drums2.ck
 Filename:  Drums2.ck
 Filesize:  4.95 KB
 Downloaded:  64 Time(s)
No matter how much society beats it out of me, I STILL want to make the world a better place. I am sick of the abuse yet I am powerless to stop it.
Audio files: 173
G2 patch files: 76
PostPosted: Mon Jun 08, 2009 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried moving drums.hit() up inside the if block and then raising the LPF frequency to 100. That got a bit more space between the beats.
Code:
// the patch
drums.output => dac;
drums.output => FullRect fwr => LPF lpf => blackhole;
100 => lpf.freq;
// play the music
spork ~ play.drummer();
// time loop
while (true) {
    second => now;
// the player class
class player {
    float prev;
    float next;
    fun void drummer() {
        while(true) {
            next => prev;
            lpf.last() => next;
<<< "Hej", Math.fabs(next), next >>>;
            if (Math.fabs(next) <= noise) {
                drums.BD();
            drums.hit();
            drums.SD();
/Stefan
Audio files: 173
G2 patch files: 76
PostPosted: Mon Jun 08, 2009 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Clever envelope follower trick, BTW! Smile
/Stefan
Inventor
Audio files: 236
PostPosted: Mon Jun 08, 2009 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
That and a little tweaking of the constants did the job! Thank you Stefan!
Les
Inventor
Audio files: 236
PostPosted: Mon Jun 08, 2009 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, here is the result. It is a drum machine of sorts. It does a BPF of the output signal, breaking it into bands and then envelope following each band. Each drum type (8 of them) in kijjaz's drum class triggers when it's band falls below a variable threshold. It's kinda lame but it's something, whatever...
Les
Drums3.ck
 Filename:  Drums3.ck
 Filesize:  5.78 KB
 Downloaded:  62 Time(s)
Niio1
