<on air> faux pas quartet and friends Music From Last Thursday
Why does this use so much CPU?
Page 1 of 1 [7 Posts]
mrcold
PostPosted: Fri Jun 19, 2009 11:08 am    Post subject: Why does this use so much CPU? Reply with quote  Mark this post and the followings unread
Why does this use so much cpu?
All was fine until I added the 'ch' function at the end.. when I did that the thing ate all of my cpu within about 10 seconds?
Have I done something wrong, or is this just not optimised correctly?
Code:
// bandlimited ugens (Blit, BlitSaw, BlitSquare)
Blit s => Pan2 p;
p.left => JCRev r1 => dac.left;
p.right => JCRev r2 => dac.right;
// initial settings
.5 => s.gain;
.1 => r1.mix;
.1 => r2.mix;
// an array
[ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 ] @=> int hi[];
[ 0, 2, 4, 7, 9 ] @=> int hi2[];
// set the harmonic
5 => s.harmonics;
// spork the pan control
spork ~ dopan();
//sporkchords
spork ~ chords();
//spork ch
spork ~ ch();
// infinite time loop
while( true )
   32 => int i;
   Std.rand2( 0, 2 ) => int rand;
if( rand == 1 )
//<<<"chrom">>>;
   while(  i > 0 )
      Std.mtof( 33 + Std.rand2(1,3) * 12 +
        hi[Std.rand2(0,hi.cap()-1)] ) => s.freq;
//mess with the rhythm
    Std.rand2(0,3) => int rh;
      if( rh == 0 )
         240::ms => now;
         i - 4 => i;
      else
         120::ms => now;
         i - 2 => i;
else
//<<<"penta">>>;
   while( i > 0 )
      Std.mtof( 33 + Std.rand2(0,3) * 12 +
        hi2[Std.rand2(0,hi2.cap()-1)] ) => s.freq;
       120::ms => now;
      i - 1 => i;
// pan control
fun void dopan()
    float t;
    while( true )
        .7 * Math.sin(t) => p.pan;
        .005 +=> t;
        10::ms => now;
//chords
fun void chords()
TriOsc t1 => Gain g => Envelope e => dac;
TriOsc t2 => g => e => dac;
TriOsc t3 => g => e => dac;
.5 => g.gain;
2000::ms => e.duration;
while( true )
    hi2[Std.rand2(0,hi2.cap()-1)] ) => t1.freq;
    hi2[Std.rand2(0,hi2.cap()-1)] ) => t2.freq;
    hi2[Std.rand2(0,hi2.cap()-1)] ) => t3.freq;
   Std.rand2(0,3) => int chrand;
if( chrand != 3 )
      .5 => g.gain;
      1920::ms => e.duration;
        //envelopstart
        e.keyOn();
        //wait
        1920::ms => now;
        //envelopstop
        e.keyOff();
        1920::ms => now;
else
        //envelopstart
        e.keyOn();
        //wait
        1920::ms => now;
        //envelopstop
        e.keyOff();
        now => now;
   .3 => g.gain;
fun void ch()
while( true )
Noise n => ADSR adsr => dac;
.4 => n.gain;
adsr.set(1::ms, 22::ms, .01, 23::ms);
adsr.keyOn();
80::ms => now;
adsr.keyOff();
400::ms => now;
keep in mind that I have only been learning chuck for 2 days... this is just a mutilated version of one of the basic examples Smile (I added some chords, a different scale array that plays randomly every now and then, and the beat)
THANKS
edit... I would also like any helpful comments about how I have put stuff together here...
mrcold
PostPosted: Fri Jun 19, 2009 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
... well I figured it out.
the problem is fixed my moving the Noise=>dac, and the adsr.set out of the while loop.
but thanks anyway!
Smile
kijjaz
PostPosted: Sat Jun 20, 2009 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
wow.. your patch is cute. i hope i can listen to more of your ChucK sound soon. keep posting heheh.
mrcold
PostPosted: Sat Jun 20, 2009 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Smile
I'm sure I'll need more help eventually
mrcold
PostPosted: Sat Jun 20, 2009 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
here is the finished version of this.. i cleaned it up a bit and added a pansy BD sound...
I would appreciate any suggestions or comments on it.
I realize that it is a bit simple and silly.. but whatever Smile
foo2.ck
 Filename:  foo2.ck
 Filesize:  2.56 KB
 Downloaded:  105 Time(s)
Inventor
Audio files: 236
PostPosted: Mon Jun 22, 2009 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I really like this song, I will try to play it on the next ChucK Show.
Les
No matter how much society beats it out of me, I STILL want to make the world a better place. I am sick of the abuse yet I am powerless to stop it.
mrcold
PostPosted: Mon Jun 22, 2009 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
word!
I am working on another one which is pretty much the same thing but with a breakbeat in it.. If I get it done I'll share it Smile
Niio1
