  DarthBuddha Meat Pinata http://meatpinata.com
  Shane Morris Atmosphera #32 - "Friday the 13th"
Found another Relic
Page 1 of 1 [5 Posts]
richardc64
Audio files: 12
PostPosted: Mon Jan 25, 2010 8:12 am    Post subject: Found another Relic
Subject description: The remains of my d.i.y. RTL Trainer
I mounted a piece of non-clad fiberglass on a wood frame and drew logic symbols on it with felt marker. You see here JK flip-flops, inverters and gates, the last looking much like 2-input inverters because that's how they were illustrated in Don Lancaster's RTL Cookbook, making no distinction as to whether they were positive logic NANDs or negative logic NORs. The worst part was drilling all the holes for IC sockets -- without benefit of a drill press! You can see through the board the residue left on the underside from adhesive copper d.i.p. patterns.
All the IC pins (except +V and Gnd,) were brought out to 4-40 screws, thread end up. Experimental patching was done using alligator clipleads. If I were to repeat this method on a Lunetta I'd probably use longish 2-56s.
Once my RTL synth was developed, and solderless breadboards were starting to become available, (replacing the old breadboarding methods of terminal strips, Fahnestock clips and other spring mechanisims,) I felt that this monstrosity was no longer necessary and disassembled it. Eventually I used chunks of the fiberglass board for one purpose or another; small circuits, using more of those adhesive copper patterns, or for small panels.
 Filesize:  90.92 KB
 Viewed:  45 Time(s)
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
droffset
PostPosted: Tue Jan 26, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pretty cool, out of curiosity, how did you connect the wires to the screws? I end up with a messy blob of solder when I try such things, did you use nuts?
https://docs.google.com/Doc?docid=0AZIwOP-PR9sSZDlidzgzbV8wY3RjenJqanY&hl=en
Edit: Spelling mistakes.
richardc64
Audio files: 12
PostPosted: Tue Jan 26, 2010 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just used solid wire, wrapped a stripped end once around close to the screw-head and tightened down the nut on the other side of the panel. You could also use tinned stranded wire.
Solder generally does not "stick" to screws.
electri-fire
G2 patch files: 4
PostPosted: Fri Jan 29, 2010 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah... I don't understand this widespread preference for stranded wire. Non-stranded stays put when bent to place, can be bent in all directions (for repair of damaged traces, soldering to cut traces for inserts etc).
Also when soldering to closely spaced pins on existing circuits, with stranded wire you get shorts more often, especially with resoldering.
Tinned stranded wire always breaks where the tinning ends doesn't it? And then shorting. (excuse the rant).
RF
Audio files: 29
PostPosted: Fri Jan 29, 2010 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got an Elektor Formant synth that was built back in the '70's - and most of the flying wires and harness were built using solid wire. The first huge job I had to take care of when I got it was to repair a LOT of connections where the solid wire was soldered to the PC board. Solid doesn't flex well, to say the least - especially at the stripped ends.
If you use solid - dress and wire tie very carefully so it will not move.
bruce
www.sdiy.org/rfeng
Niio1
