jmejia
Posted: Fri Feb 05, 2010 11:12 pm Post subject:
dirt cheap/low parts filter? |
i'm working up a little series of cmos based module pcbs for a super cheap modular synth. i may make module kits if there's interest - the first board is at the pcb shop now - it's a voice board with a 40106, 4093, 4040, and 4030 - and a couple summing busses. (not too different from bbob's awesome looking board - but with a bit of a more single application purpose)
i'm looking for a super simple (but sonically interesting) filter to put on a filter board i'm starting to plan. i'm not really concerned w/ real CV - but some type of modulation from the square waves would be nice. my main design goal is low parts. i'd like to stick with cmos if possible - but I'm also considering something like this: http://thesquarewaveparade.com/images/srlpf.jpg
anyone have suggestions? i'm thinking since all my sources are squarewaves - i should put a little passive RC lpf at the modulation input of whatever filter circuit i choose - then i should be able to get smoother voltage sweeps from my square waves right? (transferrable into resistance sweeps with an LED+photocell if the filter circuit I pick has no CV input. . .)
am i on the right track here? anyone have favorite cmos filtery/wave shapey circuits? |
DGTom
Posted: Sun Feb 07, 2010 12:12 am Post subject:
without op-amps right?
cheack out the BugBrand WOM for a simple boost / tone set-up.
I've had great success with the 4069 + vactrols in a crude LPG & VCF as well as some pretty good boosts, fuzzes & waveshaper type things. |
jmejia
Posted: Sun Feb 07, 2010 12:37 pm Post subject:
| awesome! sounds like that chip might be the way to go! do you have any 4069 sound samples handy? |
ezekiel
Joined: Oct 17, 2009 Posts: 29 Location: Columbus Ohio
Posted: Tue Feb 09, 2010 6:19 pm Post subject:
An XOR or NAND can function a little like a filter when you feed audio in one input and feedback the output to the other input, and either:
a. pass the feedback through a variable resistor with a capacitor to ground, or
b. pass the feedback through a capacitor with a variable resistor to ground (or to +V).
To make it voltage-controlled, replace the variable resistor with a vactrol.
A couple of these pseudo filters in a chain and you have a diverse-noise synthesizer. Best I found. Doesn't lose volume as bad as simple passive RC filters.
I tried the same with a shift register and various feedbacks and DAC output etc, but couldn't get much of a filter-like effect. |
DGTom
Posted: Tue Feb 09, 2010 8:12 pm Post subject:
+1 for logic filters;
http://www.youtube.com/watch?v=Jn3Uy2zbcLI
not always possible to get a trad. input -> output filter, but, there are some great sounds hidden away in those CMOS
thanks for reminding me, i really need to revisit this switched capacitor 4093 filter idea. |
Top Top
Posted: Wed Feb 10, 2010 11:14 am Post subject:
I know it's not cmos, but last night I breadboarded the Tim Escobedo Q&D VCF, which is really simple (low parts count), and works well, with a nice squelchy sound at times. It can also take a straight voltage control signal (no vactrols needed).
http://www.jiggawoo.eclipse.co.uk/guitarhq/Circuitsnippets/simplevcf.gif
Though the "logic filter" sounded great in that clip too. |
jmejia
Posted: Tue Feb 16, 2010 3:04 pm Post subject:
thanks for the suggestions!
so sort of on the same topic... is there a nice easy way to get slow lfo-like swoops with cmos chips? would a lowpass filter on a square lfo get me anywhere near that at all or is there a better way? |
Top Top
Posted: Tue Feb 16, 2010 3:17 pm Post subject:
| jmejia wrote: | thanks for the suggestions!
I've tried with putting some high uF caps to filter a square LFO. It worked ok at lower depths, but at high depths you can still hear the shift pretty suddenly.
Here is a very simple LFO that does saw and triangle, though it is not with CMOS. I've built one, but in my experience you need to drop the last (R6) resistor to 470 ohms. Also ignore the info about mods and omit switch 2 (the LFO is referring to another circuit).
[img]http://www.avwz35.dsl.pipex.com/uglyface%20lfo%20&%20mods.jpg[/img] |
monokinetic
Posted: Wed Feb 17, 2010 1:03 pm Post subject:
Tom, nice video! I for one would be very interested in a bit more info on it
| Quote: |
I read the youtube description and if I understand, you are using the caps on the 4066 to vary the filter? What's the hand rolled vactrol up to?
David |
DGTom
Posted: Wed Feb 17, 2010 8:23 pm Post subject:
I'll try to dig up my notes & get a rough schem together.
When I tried to transfer that idea from breadboard to module it was kind of an epic fail my building skills are much more refined now so I really should go back to it, I forgot how cool that video sounded, good thing I recorded it!!
But yeah, thats the basic idea, on the 4093 line up several caps thru the switches of the 4066, so that as more / each switch is opened the freq. of the 4093 osc. changes. If you did four you could get stepped filter sweeps using a binary counter to drive each switch in sequence. I think I was only using 2 switches / caps.
The whole thing uses 2 gates from the 4093 as oscillators. The vactrol is being used to get CV over the firsts frequency, the 2nd osc is having its caps switched as well as manual sweeping of its pot. |
Top Top
Posted: Tue May 11, 2010 3:07 pm Post subject:
I built this one last night. It's even cmos and only a handful of parts:
The voltage regulator can be ignored if you are running off a power supply/wallwart.
I changed the .0015uF cap to .01uF to get a deeper frequency sweep and used a 25k pot for the sweep. It's a nice squelchy/farty sounding filter.
Ajax
Joined: Apr 05, 2010 Posts: 63 Location: San Francisco
Posted: Sun May 16, 2010 10:58 am Post subject:
Came across this:http://hyperphysics.phy-astr.gsu.edu/HBASE/electric/filcap2.html#c1
Seems easy as hell, low parts, low mantinance. I had one question though: What's the capacitor hooked up to on that bottom connection? From the output of the resistor, then to parallel with what? |
Top Top
Posted: Sun May 16, 2010 11:40 am Post subject:
| Ajax wrote: | Came across this:http://hyperphysics.phy-astr.gsu.edu/HBASE/electric/filcap2.html#c1
I believe it would be parallel to ground. Upper rail would be signal, bottom is ground. That page shows the basis for LPF design that all LPFs use to some degree (sometimes with additional active components, or in a feedback loop.
It will work for sure as is, but the main thing is that there will be no resonance and there will be a loss somewhat in amplitude. It is basically like a guitar tone control. |
Ajax
Posted: Sun May 16, 2010 3:50 pm Post subject:
| Top Top wrote: | | Ajax wrote: | Came across this:http://hyperphysics.phy-astr.gsu.edu/HBASE/electric/filcap2.html#c1
Yeah, that's what I was thinking about the ground rail.
And not having resonance would be sad, but I figure for a quick, dirty filter, it's better than nothing, eh?  |
