Streaming and Network address translation
Page 1 of 1 [5 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue May 18, 2010 6:43 am    Post subject: Streaming and Network address translation Reply with quote  Mark this post and the followings unread
After signing up for the upcoming Summer Solstice 2010 event I started thinking about how to figure out the technical details of it and discovered that my internet provider uses network address translation. It means that I don't have a direct connection to internet that prevents the use of an application like Nicecast.
The only way I have to solve the problem (afaik) is to get a public IP address.
My provider sells it at a small hourly fee.
I have already tried it out with Nicecast and it seems to work, at least when I am brodcasting.
I don't know yet how to configure it to send data to the electro-music radio that does the broadcast. I guess some operator will give me some hint Wink
Audio files: 218
G2 patch files: 319
PostPosted: Tue May 18, 2010 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I dont think NAT would be a problem Carlo for radio participation ... as I understand it Nicecast can act as a server as well. For such usage a fixed IP would be needed, but not for beaming your signal to one of our servers.
When I get home this evening (probably around 21:00 your time) I'll make a port (server) for you and will PM you the connection details. Once you got those it would be handy if you'd go to the chatroom - people like Paul or Les would be able to talk you through the Nicecast configuration.
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue May 18, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Jan Exclamation
I will Very Happy
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed May 19, 2010 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I dont think NAT would be a problem Carlo for radio participation...
I guess you are right because I just beamed my signal to the port you gave me and it was successfully open Cool wow!
jfox
Radio operator
Audio files: 26
PostPosted: Wed May 19, 2010 2:18 am    Post subject: em274 Reply with quote  Mark this post and the followings unread
Hi Carlo,
Welcome to the wonderful world of Streaming Radio... Very Happy
I look forward to catching your stream. party!
john.
