2011 Build Pictures
Page 18 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 16, 17, 18, 19 Next
MadScientist
PostPosted: Thu Dec 08, 2011 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Remember that wood is an very good thermal insulator. With your amazing cabinet, the heat generated inside can only be conducted away through the front panels, and that is assuming you won't be covering those with wood as well. Very Happy
Adding to this is that your panels are tilted back, making it even more difficult to cool the inside through them.
For that reason putting the PSU inside the case may be asking for trouble, depending on how it is designed (linear, switched mode) and how much power you expect the completed synth to draw.
diablojoy
PostPosted: Fri Dec 09, 2011 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
heat is a good point. I will have to take some measurements once the cab is full though and then see if i need to add vents or not
My thanks to scrog productions for the idea for the power scheme
which i am still working on . It is a 18v-0-18v 300VA centre tapped torroidal feeding 8 x lm317/337 regulator boards [ only one is shown in pics ] via 2 x 35 amp bridge rectifiers and 4 x 18000uf caps
I expect to draw no more than 200-300mA max through each regulator so they should run pretty cool
I have also added a delay board to bring each reg board on line
one after another to limit the initial start up current.
ask where the hell am I
as good an answer as any
bubzy
Audio files: 64
PostPosted: Sat Dec 10, 2011 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
"several" nights work. i didnt count so i dont really know Very Happy
Fonik x4046 vco pcb & waveshaper
buchla 218 portamento
yusynth adsr
thomas henry 21c vca (fonik pcb layout)
cgs steiner vcf
thomas henry 21c s&h
some lfo i found here on forum cant remember
thats it. has banana connectors for power on bottom left of panel.
 Filesize:  312.46 KB
 Viewed:  503 Time(s)
MadScientist
PostPosted: Sat Dec 10, 2011 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
diablojoy wrote:
[...] It is a 18v-0-18v 300VA centre tapped torroidal feeding 8 x lm317/337 regulator boards [ only one is shown in pics ] via 2 x 35 amp bridge rectifiers and 4 x 18000uf caps
I expect to draw no more than 200-300mA max through each regulator so they should run pretty cool.[...]
If you wish, then I wouldn't mind giving your PSU configuration the full, custom mad scientist analysis, assuming you haven't done so already. I believe this would be worthwhile in this case, given how much effort you have spent on the project.
If so, then please measure the copper resistances of the toroidal transformer, primary and total (across 36V) secondary. The secondary resistance in particular is likely to be quite low, so a rough value will be quite adequate.
Also, I assume you are using 2x 18'000 uF for smoothing each unregulated supply rail, 4 in total?
PostPosted: Sat Dec 10, 2011 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
bubzy wrote:
thats it.
audio? i wanted to hear something...
PostPosted: Sat Dec 10, 2011 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a nice little box! Smile
Yes... Sound?! Very Happy
ACHTUNG!
diablojoy
PostPosted: Sat Dec 10, 2011 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes,
just after the rectifiers.
will try to take some measurements when i get home
yes please so do I
nice mix of modules bubzy
PostPosted: Sun Dec 11, 2011 1:06 pm    Post subject: C-MOnSter
Subject description: CMOS Based Polyphonic Synthesizer
Well, I just barely made it into the 2011 build thread. I started this project a year ago as my first DIY synth project and had to learn everything along the way.
I made a keyboard controlled top octave synth that uses almost exclusively simple CMOS circuits to create the sound. The full explanation is here:
http://www.jacobwatters.com/c-monster.php
And here is the sound demo:
Thanks to everyone here on this site for helping to answer my questions and guiding me through the entire process.
 Filesize:  5.36 KB
 Viewed:  481 Time(s)
JacobWatters.com
PostPosted: Sun Dec 11, 2011 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
so you finally accomplished it? great! will have to wait until tomorrow to watch the vid, though. i am realy looking forward to it!
umschmitt
PostPosted: Sun Dec 11, 2011 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow ! Beautiful & brutal synth ! With lots of radical options it seems ! Nice use of a LED display, too.
::U::N::S::C::H::N::E::L::L::
EdisonRex
Audio files: 172
PostPosted: Sun Dec 11, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good demo, Jacob. You've done awesomely. Very Happy
Garret: It's so retro.
inlifeindeath
PostPosted: Sun Dec 11, 2011 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds great! glad you got it done as well!
i like the 'things i learned' section on your site as well haha
wmonk
Audio files: 15
PostPosted: Sun Dec 11, 2011 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow Jacob, that is really awesome! and sounding real funky afro
Heh, and the video looks a lot more CMOS compared to your professional vids Laughing
Weblog!
Audio files: 705
PostPosted: Mon Dec 12, 2011 4:13 am    Post subject: Re: C-MOnSter
blabla,.. showing of awesome synth
thumright well-done thumleft
Audio files: 42
PostPosted: Mon Dec 12, 2011 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool equipment from Bubzy and Cynosure.
The CMOnSter's sound is bigger than life!
Audio files: 42
PostPosted: Mon Dec 12, 2011 1:20 pm    Post subject: a new track with my modular synth Reply with quote  Mark this post and the followings unread
btw -- in case you didn't notice, I just posted a track from my DIY modular:
http://electro-music.com/forum/topic-51049.html
In particular, it showcases the some of the Yusynth filters: (the VCS filter clone, the Steiner filter clone, and the Fixed Filter bank). I also used the fonitronic Voltage-controlled Ring Modulator, and some CGS modules (Super Psycho Modulation Source, Wave shaper, Modulo magic), too.
PostPosted: Mon Dec 12, 2011 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all the kind words. I'm glad you guys like the sounds it makes. I'm very proud of my little monster synth. Very Happy
JacobWatters.com
umschmitt
PostPosted: Tue Dec 13, 2011 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
(This is technically a build from last year, but I feared doing something evil by reviving the 2010 thread.)
Ladies and gentlemen, meet
the Atari Punk Chewbacca !
It consists of a collision of John Hollis' Crash Sync and an Atari Punk Console. Controls are frequency and pulse width (with switchable LDRs), input and output volume, switches for effect or generator modes and input signal routing to freq or PW. And there's a tiny LED in the middle of the fur.
No APCs were harmed in the process.
 Filesize:  380.39 KB
 Viewed:  291 Time(s)
Audio files: 705
PostPosted: Sat Dec 24, 2011 7:32 pm    Post subject: Ho, Ho, Ho
Subject description: Annual Christmas build - 2011
I just finished my annual X-mas build for this year. It has a sound chip with
some added extra's and off course some flashy X-mas lights.
santa Ho, Ho, Ho, Merry X-mas everybody @ electro-music.com santa
Annual X-mas build - 2011
 Filesize:  480.26 KB
 Viewed:  306 Time(s)
 Filesize:  450.65 KB
 Viewed:  299 Time(s)
PostPosted: Tue Dec 27, 2011 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
haha! what a nice build. look like the ultimate christmas pinball machine to mee...
Captain Biscuits
PostPosted: Wed Jan 11, 2012 3:57 pm    Post subject: A Modular is never Finished but . . .
Subject description: mine has reached a sort of "that'll do for now" moment.
Been building bits of this for about 2 years on and off I guess starting with an MFOS mini synth, then an MFOS 10 step, 3 VCOs, etc etc
Finally completed a case with 2 LFOs, a dual AR EG and a low pass filter around Christmas.
Planning to play with some CMOS/Lunetta bits to get some interesting beats (largely based on Bruce's You Tube Vid of his Quad bass and lunetta combo) next.
Then there's a Klee part made which needs finished and 2 or 3 Thomas Henry VCOs to make up.
Oh - and a Chaquo pcb on the way from the Bridechamber and an MFOS MFM to play with - and an Appendage board in a cupboard somewhere Smile
So not finished - but it's reached a point where I'm kind of chuffed with it at last and enjoying playing with it!
 Filesize:  556.79 KB
 Viewed:  356 Time(s)
 Filesize:  297.11 KB
 Viewed:  311 Time(s)
Audio files: 705
PostPosted: Wed Jan 11, 2012 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks great, love the pixie panels! dwarf
Audio files: 212
PostPosted: Wed Jan 11, 2012 5:31 pm    Post subject: Re: A Modular is never Finished but . . .
wow! looks amazing...
PostPosted: Wed Jan 11, 2012 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Captain Biscuits - I love the panel designs!
JacobWatters.com
fluxmonkey
PostPosted: Thu Jan 12, 2012 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you didn't click on Cap'n B's pics to get the fullsize closeups, go back and do it now! wonnerful on all counts, CB.
on a side note, innit time for a new 2012 build thread?
www.fluxmonkey.com
