aseawolf
inlifeindeath
Joined: Apr 02, 2010 Posts: 316 Location: Albuquerque, NM
Posted: Wed Dec 21, 2011 11:46 am Post subject:
the control pin on the 556 is where the CV goes, so pins 3 and 11. wire each 4017 output through a pot, and then sum the output voltages and send to the CV pins. You should check out HexInvertor's Simple Seq project on the forum here.
You can also look up datasheets very easily. _________________ http://www.youtube.com/user/borisandfef |
aseawolf
Posted: Wed Dec 21, 2011 12:09 pm Post subject:
So the pins are the control ones 3 & 11 .Shoud i put diodes 1N4148 as in the image [img] http://note.monoanimal.com/images/apccircuit_2.jpg [/img].Would you like to give me a link for:"HexInvertor's Simple Seq project"I can't find it .Thanks |
umschmitt
aseawolf
Posted: Wed Dec 21, 2011 12:31 pm Post subject:
Thanks |
umschmitt
Posted: Wed Dec 21, 2011 1:31 pm Post subject:
De nada. As explained on the sketch you provided, you should connect the output of the sequencer to pin 2 of the 556 (for pitch control) - and/or pin 12 (for pulse width control, whatever it could lead to, hopefully fun). On the APC I built, I let the control pins unconnected.
And yes, you need to use diodes as shown, to make each step's tension independent from the others'… _________________ ::U::N::S::C::H::N::E::L::L:: |
aseawolf
Posted: Wed Dec 21, 2011 1:49 pm Post subject:
Gracias.So pin 2 for pitch pin 12 for pulse and control pin disconnected |
aseawolf
umschmitt
Posted: Sun Dec 25, 2011 12:30 pm Post subject:
Concerning pots and diodes, it looks fine to me. Your LED resistors seem way too huge to let them glow. I'd say they should be in the zone around 4k7-10K if you run it from 9 volts (babyseq schem says 18k !) but it depends greatly of the actual LEDs you use !
(and don't forget to try the seq output on pin 12 on the 556 for octave madness !) _________________ ::U::N::S::C::H::N::E::L::L:: |
aseawolf
Posted: Sun Dec 25, 2011 12:47 pm Post subject:
Don't care about the leds I'm not using it with those resistors.Anyway I've connected pots and diodes using that layout and I've connected all to pin 2 of the 556 (as I wrote in the image)and it isn't working.It doesn't change pitch .Now i will try with pin 12. |
umschmitt
Posted: Sun Dec 25, 2011 1:53 pm Post subject:
Did I really write pin 2 ? Oh my ! Sincere apologizes ! Err I meant err… pin 1. My mistake. I was actually doing mental gymnastics between the 556, my double 555 circuit and respective datasheets… (and at one point I followed monoanimal's drawing)
So pin 1. I'm far from a genius with those electronic things, but I'll stay connected here for a while tonight, so if you're working on your APC please post your results & questions, if I can help without mistakes, who knows…
(yeah and just one resistor between all LEDs' cathodes and ground is Ok, but first get it to work !) _________________ ::U::N::S::C::H::N::E::L::L:: |
aseawolf
Posted: Sun Dec 25, 2011 1:57 pm Post subject:
OK OK It is pin 1 thanks I was so sad it wasn't working. On pin 12 it works greatly on pulse .Last question . Can i use the same pot for the two pins 12 and 1 or it won't work.Thanks |
umschmitt
Posted: Sun Dec 25, 2011 2:30 pm Post subject:
Great news ! I'm glad it works ! Now let the fun begin !
So you mean feeding both inputs with the sequencer ? Just connecting things as is, I fear that there would be interaction between the two timers inside the 556. It's not like there is a risk of breaking something expensive here, so try it ! (and I don't think you'll break anything, to be honest) I'm curious to know what would be the result. Maybe a bit of chaos… Otherwise, with two diodes placed at the 1 & 12 inputs, it should work.
(further experiment : try to feed pin 4 (reset) with LOUD signal. Brutal hardsync here. But remember that reset at 0v means silence at output ! I think the APC works with that pin unconnected. Mine works, that is. Oh and you can apply the same to pin 10 of course !) _________________ ::U::N::S::C::H::N::E::L::L:: |
punkconsole
Posted: Sat Feb 24, 2018 2:59 am Post subject:
Wiring the Atari punk console to the sequencer Subject description: APC + sequencer |
inlifeindeath wrote: | the control pin on the 556 is where the CV goes, so pins 3 and 11. wire each 4017 output through a pot, and then sum the output voltages and send to the CV pins. You should check out HexInvertor's Simple Seq project on the forum here.
You can also look up datasheets very easily. |
Hello, i do have the same problem.I wanto to connect a sequencer to an Apc.I'm trying as described below but I can't.I'm connecting the output of the sequencer to CV of the 556.Should I connect the Vin of the Atari punk console( I mean the circuit must be ON?) If you want I can upload a picture. |
Audio files: 705
punkconsole
Posted: Sat Feb 24, 2018 7:52 am Post subject:
PHOBoS wrote: |
Are you powering both circuits from the same supply ? If not you will also have to attach the GND connections together.
A picture could be helpful. |
Yes I do connect both with the same power supply and both work .In few minutes I m going to upload a picture.Thank you |
punkconsole
Audio files: 705
punkconsole
Posted: Sat Feb 24, 2018 11:46 pm Post subject:
3& 11 of ne556 |
No.3and11 are completely free.I am not sure about the diodes I am using.Could it affect the results? |
Audio files: 705
Posted: Sun Feb 25, 2018 4:15 am Post subject:
The diodes shouldn't be a poblem (and are needed) unless you used zener diodes.
Lets focus on the APC first to see if it can actually do something with a CV. So leave the sequencer out for now and connect
the two outside pins of a potentiometer to your powersupply (+/GND) and the middle pin to pin 3 or 11 of the APC. Try if
it has any effect if you turn the potentiometer.
edit: just looked at some schematics and it seems that in some cases the discharge pins are used (which doesn't really
make much sense to me) or the treshold pins, which makes some sense. So you could try connecting it to pins 2 or 12,
which is also mentioned earlier in the thread. _________________ "My perf, it's full of holes!"
punkconsole
Posted: Sun Feb 25, 2018 11:24 am Post subject:
PHOBoS wrote: | The diodes shouldn't be a poblem (and are needed) unless you used zener diodes.
which is also mentioned earlier in the thread. |
So I have connected the 2 outside pins of a pot to + and - and the middle pin to 3 and 11 .When I use that pot it does the same sound that the atari punk console does when I use one of the 3 built in pot( it changes the tone) |
Audio files: 705
punkconsole
Posted: Wed Feb 28, 2018 10:19 am Post subject:
PHOBoS wrote: | well, that's good I think
I would use either pin 3 or 11, but both works too and you could add a switch for it (or make 2 sequencers).
So, with the sequencer you don't get the same effect ?
Do you have an oscilloscope or at least a volt-meter to test the output of the sequencer ? |
No sir I do not have an oscilloscope but I have a voltmeter.No with the sequencer I do not have any effect.So if I am understanding ...is it possible that the output of the sequencer is too low?Thank you |
punkconsole
Posted: Sun Mar 04, 2018 10:00 am Post subject:
punkconsole wrote: | PHOBoS wrote: | well, that's good I think
So my input is 9V.The output is 3V |
Audio files: 705
Posted: Sun Mar 04, 2018 11:37 am Post subject:
oops,. my apologies for leaving you hanging there.
Assuming it is the maximum voltage you get out of it 3V is rather low. Is that without the APC connected ?
If you measure the output of the sequencer after the diodes you might need to add a resistor to GND for
proper measurement btw. I wonder if the LEDs might be limiting the voltage somehow. What's the voltage
you get directly out of the 4017 ? _________________ "My perf, it's full of holes!"
