Mono -> Stereo
Page 1 of 1 [9 Posts]
sebber
G2 patch files: 31
PostPosted: Mon Feb 27, 2012 2:58 am    Post subject: Mono -> Stereo
Subject description: "Wide Stereo"
Hi everybody,
I remember that I read a long time ago about the technique to turn a mono signal into a "sort of" stereo. I found a patch here http://electro-music.com/forum/viewtopic.php?highlight=stereo&t=38523 but that has far too many effects. I think what I'm refering to is much more in line with the "wide stereo" effect sometimes found on cheap boom boxes. Any pointers?
Fish don't swim. They dive.
For everything else: The Patcher's Toolbox
Roland Kuit
G2 patch files: 124
PostPosted: Mon Feb 27, 2012 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Sebber,
From my SoundLab II. The Delay module can be modulated by a lfo module too:
 Filesize:  65.96 KB
 Viewed:  1930 Time(s)
Pseudo Stereo.pch2
 Filename:  Pseudo Stereo.pch2
 Filesize:  1.11 KB
 Downloaded:  192 Time(s)
Roland Kuit
http://rolandkuit.com/
sebber
G2 patch files: 31
PostPosted: Mon Feb 27, 2012 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. What I saw from SoundLab II is absolutely stunning and a joy to look at!!
Is this the "purest" way to do it? I guess the LFO adds modulation as opposed to keeping the signal the same?
Roland Kuit
G2 patch files: 124
PostPosted: Mon Feb 27, 2012 4:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Sebber.
No, this is not the purest way. It is phase shift actually. With a lfo it will become a phaser. But when you give it just a minimum effect it will be nice.
The simplest form is here:
 Filesize:  50.31 KB
 Viewed:  1889 Time(s)
 Filesize:  70.42 KB
 Viewed:  1864 Time(s)
Roland Kuit
Audio files: 211
G2 patch files: 92
PostPosted: Mon Feb 27, 2012 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
+1 on the delay module for making stereo, with or without LFO. It was one of the first tricks I learned on the old micro modular, and I still use it all the time!
Roland Kuit
G2 patch files: 124
PostPosted: Mon Feb 27, 2012 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
A very few simple solutions of 15. Others in SL II are very sophisticated. Even with the azimuth factor:)
Roland Kuit
sebber
G2 patch files: 31
PostPosted: Mon Feb 27, 2012 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, guys. Posting a question and receiving multiple knowledgeable results in just a few hours makes this forum the best you can find.
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Mar 03, 2012 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a nice trick that pans the odd and even harmonics of an oscillator left and right in the stereo field. Resonant filter sweep added for demonstration
HarmonixPannerTK.pch2
Panning the even and odd harmonics of an oscillator left and right in the stereo field.
 Filename:  HarmonixPannerTK.pch2
 Filesize:  1.71 KB
 Downloaded:  183 Time(s)
Roland Kuit
G2 patch files: 124
PostPosted: Fri Mar 09, 2012 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great Tim! Very Happy
Roland Kuit
