 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - automatic (noodles)
05-003-001
Page 1 of 1 [4 Posts]
Audio files: 278
PostPosted: Fri Feb 18, 2005 7:15 pm    Post subject: 05-003-001 Reply with quote  Mark this post and the followings unread
A rather simple one, "melanchodic", using up/down traveling random lines that are modified a bit by shapers and wrappers. It seems to have the blues a bit.
The drums are not quite what I want yet (it's more like a bass now, but it does the job for me). I was thinking on Arvo Pärt (but the melody would have to be simpler and more expressive then, as well).
The reason I sent this as a performance and not as a patch is that it uses MIDI sends to itself for amplitude detection/handling in the FX area. As a performance it will load OK, as a single patch I'd have to instruct yoy to load it into slot A. But it is a patch, basically, so I posted to the patch section, better, I think.
Jan.
05-003-001.prf2
A simple melodic noodle with just some light disturbances.
 Filename:  05-003-001.prf2
 Filesize:  8.58 KB
 Downloaded:  2658 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Feb 19, 2005 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent
General Elektrick
PostPosted: Sat Feb 19, 2005 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I like this a lot!
I am listening to some gypsy music in the moment and some of your patch has that sad harmonies.
That env follower > midi ctrl > morph circuit - cool
Thanks for sharing!
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
Audio files: 278
PostPosted: Sat Feb 19, 2005 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys.
This gypsy thing is something I really like (and it just keeps on creeping into my noodles :-)
Jan.
