Voltage Controlled Crossfader/VCA
Page 1 of 2 [35 Posts]
Thomas_Henry
PostPosted: Mon Aug 06, 2012 7:57 pm    Post subject: Voltage Controlled Crossfader/VCA
Subject description: Another circuit for your consideration
Hi Gang,
As promised, here is another circuit for you to play with. It can be used either as a voltage controlled crossfader or as an ordinary VCA. I hit upon this when finally realizing something that was in front of me all the time---the control currents though the voltage-to-current converter are symmetric yet opposite. It's an obvious idea once you see it and has probably been used before. But I was glad to stumble upon it.
Null out the DC thumps in the usual way. (Turn the audio inputs down, then apply a 0 to +5V square wave to the CV input.)
The usual legalese applies. Feel free to use this for personal applications but don't copy, or produce commercially. Anyone wanting to do a non-commercial PCB for EM users please contact me first.
Have fun!
Thomas Henry
Schematic --- Sheet 1
 Filesize:  53.57 KB
 Viewed:  2331 Time(s)
Schematic --- Sheet 2
 Filesize:  77.2 KB
 Viewed:  2307 Time(s)
Parts List
 Filesize:  51.65 KB
 Viewed:  1192 Time(s)
PostPosted: Tue Aug 07, 2012 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks fun Mr Henry! Cheers! Very Happy
ACHTUNG!
inlifeindeath
PostPosted: Wed Aug 08, 2012 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
can't wait to try out the new designs thomas! thanks as always for your work!
widdly
PostPosted: Wed Nov 07, 2012 8:39 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thanks for another great design Thomas.
I built it this afternoon on perf board and it works very nicely. Like the other TH designs I've built, the input ranges on all the controls are tuned perfectly.
PostPosted: Tue Sep 22, 2015 5:17 am    Post subject: Re: Voltage Controlled Crossfader/VCA
while looking around for a simple crossfader CV circuitry i found a very similiar on an old tom gamble EFM dual VCA, however, your solution is much more elegant and adds a nice touch with the overall volume control using the emitters!
thank you!
PostPosted: Tue Sep 22, 2015 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, thanks Thomas!
(Previous post deleted; still need the reminder not to post before finishing my tea)
Sethkaine
PostPosted: Mon Sep 28, 2015 2:48 am    Post subject:  expo converter Reply with quote  Mark this post and the followings unread
Hello Thomas,
I'm trying myself to your OTA designs : learning, breadboarding, etching, soldering, testing, listening. I love your designs from birthofsynth by the way. Wink
Sounds great to discover "new to my knowledge" designs in this forum. I'll going to try it out.
continue the good job and a big thank you for your schematics you're pleasing my ears.
my youtube channel - https://www.youtube.com/user/SethKaine/videos
my paper mix - https://paper.fiftythree.com/1865071
wackelpeter
Audio files: 10
PostPosted: Tue Feb 02, 2016 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice design Thomas, many thanks for that very cool circuit. Very Happy
It's not only a Crossfader or VCA also some kind of manual or voltage controlled wavefolder/mangler when you feed two waveforms from one VCO into it.
Like it thumleft
Makes me feel i need a second one... Smile
richardc64
Audio files: 26
PostPosted: Tue Feb 02, 2016 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
And still no love for mine.
http://www.sdiy.org/richardc64/mmvca/
Revenge is a dish best served with a fork... in the eye
LFLab
PostPosted: Wed Feb 03, 2016 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Which IS very interesting! Have you tried this with the LM13700 schematic already, Richard?
roglok
PostPosted: Wed Feb 03, 2016 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reminder, richard. i've meant to prototype your circuit but totally forgot about it...
richardc64
Audio files: 26
PostPosted: Fri Feb 05, 2016 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Negative, LF. I have other priorities. But anyone is welcome come to experiment with the idea: Capacitor couple the audio inputs, give it a better current source, perhaps with Lin-Log response.
Etc.
wackelpeter
Audio files: 10
PostPosted: Fri Feb 05, 2016 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Etc.
Damn... that's what i forgot on my TH X-Fader because i couldn't wait to test it.... Smile didn't recognized the two blank holes on my frontpanel...
sompost
PostPosted: Sat Feb 27, 2016 2:58 am    Post subject: Crossfader-only Reply with quote  Mark this post and the followings unread
Hi all,
I would like to use this great circuit as a voltage controlled mixer (crossfader option on sheet 1 above). Because the master level would always be set to maximum level, and envelope control would not be needed, the whole branch to the left of R11 (between Q1 and Q2) seems unnecessary for a crossfader-only use. Am I right?
What would I have to replace that branch with? Do I need the buffer (IC3c) or can I just supply +15V via some resistance to the point between Q1 and Q2? What would that resistance be?
4b11b4
PostPosted: Sat Sep 17, 2016 12:47 pm    Post subject: Re: Crossfader-only Reply with quote  Mark this post and the followings unread
sompost wrote:
Hi all,
Did you ever build this?
LFLab
PostPosted: Sun Sep 18, 2016 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
By the way, I have built RichardC64's version with LM13700, and it works fine.
Forgot to add capacitors to the audio inputs though, and I haven't calibrated it yet, but it does work. (let me know if you'd like a few boards Richard).
sompost
PostPosted: Sun Sep 18, 2016 6:39 am    Post subject: Re: Crossfader-only Reply with quote  Mark this post and the followings unread
No, I didn't. First, I've got plenty of other unfinished business to do, and second I dropped the voltage controlled mixer from the design.
Ralph
richardc64
Audio files: 26
PostPosted: Mon Sep 19, 2016 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
That's great, LFLab. It's good to know that that past success wasn't a fluke. What values did you use for the Initial CV pot and the mystery resistor?
As for boards... Thanks for the offer, but I dunno. My prototype is still collecting dust, here. I'll let you know.
LFLab
PostPosted: Tue Sep 20, 2016 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Not sure what the mystery resistor is (maybe I should read everything before plonking something in Eagle Very Happy ), but this is what I have now, no wiring needed.
The lower section is one of Ray's (MFOS) VCA's.
(sorry for the OT discussion)
richardc64
Audio files: 26
PostPosted: Tue Sep 20, 2016 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
LFLab wrote:
Not sure what the mystery resistor is...
Oops. I neglected to include it in the 13700 schema. In the 3080 version it's at the -v end of the Initial CV pot. It's supposed to offset the range of that pot so that with no CV, when the pot is in the centered position a signal on Xin or Yin is at equal levels on both outputs.
I like that you included a normal VCA on your board. I may want one after all Very Happy
Cfish
PostPosted: Wed Sep 21, 2016 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Thomas.
so much of my modular is built from your schematics. I know I can perfboard them up and count on them to work.
That always means a lot to me. Will give this one a try.
VinL
PostPosted: Tue Jan 24, 2017 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
First post!
I've found a minor mistake in the crossfader/vca schematic. On the schematic pin 13 of the TL074 is labelled as the non-inverting input and pin 12 as the inverting input whereas it should be the opposite. I was actually building a dual version of vca-1, wich is very similar, with lm13700 and using both schematics got me stumbling on this anomaly.
BTW I love Thomas Henry designs!!! My favorites since I got into synth DIY about a year ago.
Thomas_Henry
PostPosted: Tue Jan 24, 2017 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for pointing that out.
To be clear, everyone, the pinout in the schem is correct, so build away! Only the plus and minus signs in the op-amp representation of IC3d are reversed.
Thomas Henry
ReToxx
PostPosted: Tue Feb 14, 2017 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello everybody,
I want to build a small circuit wich allows me to feed back the normal output and the inverted one of a filter back to its input by a voltage controlled crossfader. So i want to have a knob which has no output in its middle position,
full ccw would be the inverted only (which also means no output at the output;-) ), full cw would be the normal output. And I also want cv control over the crossfading, where the knob acts as a starting point for the cv...
I want to leave as much as possible, but I don't know how to deal with that amp stuff thats going to in between the two transistors...
I already left the ac/dc switch, and the attenuators at the inputs, as well as the dc offset trimmers, as i will use it only for audio. And i added an attenuverter at the cv in...
don't know if that all makes sense and what to do with the input at the transistor, maybe i could only leave the initial gain pot as a trimmer, but to what value do i have to trimm that? or can i somehow set a voltage right at the transistors and get rid of the opamps there...
thanks so much for any advice
 Filesize:  160.44 KB
 Viewed:  475 Time(s)
PostPosted: Tue Feb 14, 2017 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
i used 20k there (from +12V).
