Some PCBs
Page 1 of 1 [2 Posts]
Audio files: 35
PostPosted: Thu Jun 25, 2015 5:00 pm    Post subject: Some PCBs
Subject description: Yusynth and Ian Fritz
I've got the following PCB's to spare. Where indicated that it's a 2 PCB set (or 3), the price is for a set, not per PCB. Unless noted otherwise, all projects use boardmounted pots and 3.5mm jacks (I hate doing panel wiring.) I can supply Front Panel Design files for each. Once they're gone, they're gone -- I'm just doing this to clear out boards I don't need, and get capacitor money for the *next* project.
2PCBset Clock Divider -- 2PCBset/$25
This is the Yusynth Clock Divider, and uses the Alpha 1P8T that only Mouser carries. Mouser doesn't have it in stock at the moment either, as far as I know.http://nz.mouser.com/ProductDetail/Alpha-Taiwan/SR1712F-0108-20F0A-N9-N/?qs=sGAEpiMZZMvNbjZ2WlReYqBsoziRjTWUH8saZNpNioA%3d
MinimoogVCF -- 2PCB -- $25
This is the Yusynth Minimoog VCF. Ladder transistor filter.
SteinerParker VCF - 1PCB - $15
Yusynth SteinerParker VCF. Has LP, BP, HP, and All Pass too. Uses the Alpha 2P4T. Red PCB (so it goes fasta!)
Baby Ten Sequencer - 1PCB - $25
This is based on Fonik's schematic, and has boardmounted everything! (And lots of diodes.)
Rene Schmitz' RS-20 - 2PCB - $25/PCBset $10 Panel
This is Rene Schmitz' version of the famous MS-20 filter, with an attenuator for the Low Pass input, and an unattenuated High Pass input as well!
Experts and Nutters Only (guess which one I am... I like peanut butter sammies... no jam, though...)
BOM and schematic only with these. I'll help, but don't expect huge amounts of it.
GatSynFace -- 2 PCB - $30/PCBset $10/panel
This is my Guitar Synth Interface. It has Ken Stone's CGS60 Stompbox Interface, Harry Bissell's Envelope Follower, and Yves Usson's Comparator. I use it a lot to run pedals in the synth.
Fixed Filter Bank - 3xPCB - $35/set
This is Yusynth's Fixed Filter Bank. Insane amount of parts in this one. The silkscreen is off on one engineboard, and a link has to be made on the same board.
Edited to reflect changes.
bamboombaps
PostPosted: Mon Dec 14, 2015 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
im very poor so cant buy Sad but i have some pcbs i can trade
http://electro-music.com/forum/topic-65416.html
